SanFran 12 Posted November 9, 2019 Share Posted November 9, 2019 Any suggestions? Do people antifoul them, prop speed, or something else. Quote Link to post Share on other sites
mcp 32 Posted November 9, 2019 Share Posted November 9, 2019 Any suggestions? Do people antifoul them, prop speed, or something else. I was just reading about this the other day. http://www.kiwiprops.co.nz/cms/index.php/resources-general/antifouling Quote Link to post Share on other sites
harrytom 642 Posted November 9, 2019 Share Posted November 9, 2019 I just etched primed alloy parts and used antifoulfor alloy never had a problem.have see some use people speed. Generally used boat every week to the gremlins didn't get a chance to grow. Not sure on lanocote. Quote Link to post Share on other sites
harrytom 642 Posted November 9, 2019 Share Posted November 9, 2019 Grr prop speed Quote Link to post Share on other sites
Fish 0 Posted November 9, 2019 Share Posted November 9, 2019 We use prop speed. Quote Link to post Share on other sites
Island Time 1,227 Posted November 9, 2019 Share Posted November 9, 2019 I use std anti fouling. Works ok. Don’t forget to grease all 5 grease points. 1 Quote Link to post Share on other sites
harrytom 642 Posted November 9, 2019 Share Posted November 9, 2019 Was about to search on that. Whats the best tip for grease gun? I'm going to do it in the water this round. Also, what is current demand for going to BOI. Is diy clean with pic evidence sufficient? Or do you have to have haul receipt/clean to escape a fine? Grease in the water?? or have I misread it??need to remove phillip type screws and pump grease in till it comes out,also hub grease points,not a in the water job.find the manual as if you undo wrong screws blades/rollers come apart and thats not what you want. previous owner did just that and ended up with spare blades and rollers Quote Link to post Share on other sites
Island Time 1,227 Posted November 9, 2019 Share Posted November 9, 2019 Easy to do on a grid... Quote Link to post Share on other sites
whitepointer 34 Posted November 11, 2019 Share Posted November 11, 2019 we have a kiwi prop and on a yanmar sail drive and use prop speed, HMB boat spray do it when I haul out, I get at least 2 years between applications, very happy with it. and yes greasing is required about every 10 months ,when I start having trouble going into reverse its time for a grease, I wouldn't attempt it in the water tho , probably drop the the little screws. Quote Link to post Share on other sites
Mandy 0 Posted February 10 Share Posted February 10 When using Propspeed on the Kiwiprop blades are you using primer and the clear? Cheers, Mandy Quote Link to post Share on other sites
Black Panther 1,581 Posted February 10 Share Posted February 10 Copper coat, seems to work. Quote Link to post Share on other sites
Island Time 1,227 Posted February 10 Share Posted February 10 16 hours ago, Mandy said: When using Propspeed on the Kiwiprop blades are you using primer and the clear? Cheers, Mandy Yes. Quote Link to post Share on other sites
harrytom 642 Posted February 10 Share Posted February 10 prop speed and copper coat depends on water quality.Used Prop speed on a kiwi in tamiki river but had better results in normal antifoul. Yes I know the concept of Prop speed,few revolution and the muck should be thrown off but once its estsablished? Quote Link to post Share on other sites
whitepointer 34 Posted February 10 Share Posted February 10 I moor in HMB marina, have good results with prop speed on my kiwi prop, good for 2 years , boat gets regular use, HMB boat spray apply it, had boat for 12 years,i grease prop once a year, Quote Link to post Share on other sites
alibaba 76 Posted February 11 Share Posted February 11 Don't need to use primer on the blades, they are composite. I just use the silicon topcoat and it sticks for at least two years. The important bit is the metal boss, which must be kept clear of fouling. As above, the clue to needing regreasing is difficulty in reverse, because if the blades stick instead of swinging right across it can stall the engine. I have like others, thought about getting diver to do it in the water, but .... those tiny little screws! Quote Link to post Share on other sites
