L00seM00se
Block Identification
My Bonito has a wire topping lift down with a length of line that attaches to the boom. The height is adjusted by two clips and is a pain to use as it only gives two positions.
After looking around the other Bonitos in the yard, they all have a wire/line combination as well. However, each has a block on the end of the boom that the line runs through. These blocks have a locking system, kind of like a cam cleat or something built into them which allows adjustment of the topping lift by simply locking off the line.
I’ve been searching far and wide for one of these blocks, but without knowing the name it’s a bit hard.
I wonder if the hive mind knows what this bit of hardware is called?
Share this post
