Frank
12V Fuel Pump for Diesel.
We are looking to install a 12v fuel pump between the primary and secondary filters on our Perkins Prima Diesel (50HP) can anyone recommend a reputable product ?
Incidentally we don't need the boost its more for bleeding etc.
Share this post
Facet fuel pump
https://www.amazon.com/Facet-Solid-1-5-4Psi-30-48Cm-195-1310/dp/B01DLZZGOK/ref=sr_1_2?keywords=facet+fuel+pump+12v&qid=1581403407&sr=8-2
used to have one of these on my previous long forgotten VW Golf diesel
Another option is to fit a primary filter housing with a primer pump, eg CAV
https://www.ssldieselparts.co.uk/primers-primers-with-filters-c-263_169.html
RACOR also make them, I have one feeding my current Yanmar
Share this post
off my tank we had a bulb like on a outboard tank,it close enough so could pump with hand and bleed .old yanmar.    Most motors have a lever on the pump for bleed purposes.
Thinking if you installed an electric pump for bleeding then pump might need to run fulltime to keep diaphragm open to allow fuel to run?
Share this post
We had one, just a lift pump, but I don't know the brand sorry. I can look if you really want to know. Was just a simple centrifugal pump, not positive displacement like the engine lift pump. We have actually changed to a priming bulb, aka same as for an outboard motor. Works well, about $15 from Burnsco.
We have ours placed just after the fuel tank, before the filters. Have our water separator filter mounted very high above the engine, hence the need for a priming bulb or pump. You might think I'm a bit funny, but I like to see the filter easily, so I know immediately when we start sucking up sh*t. Its mounted just under the companionway stairs, above the engine box. Yes, we've had diesel bug before, know that song, and all the lyrics.....
Share this post
Cheers all,
Yes the point about having to have it on all the time is a concern, I will have to look at that, maybe a bypass set up is needed. Its just that the Perkins seems to take forever to purge when using the lift pump and its in an damn awkward position .
The bulb might do the trick if its displacement is substantially greater than the lift pump, certainly it will be a damn sight easier.
Share this post
Its so simple, I got mine at burnsco for $20? Its low pressure so you hardly even need hose clamps as the fuel is usually sucked from the tank to the lift pump. Very easy to put a joiner in if you  dont llke it. The first one I had for about 6 years before I sold the boat, it was still mint. Honestly it makes bleeding an absolute breeze. I think a pump might be the idea on a high flow system but for these little motors thats a bit of a complicated solution.
Share this post
