Fogg 427 Posted March 20, 2020 Share Posted March 20, 2020 When testing an engine by running at full speed for 5 mins and measuring the temp of the exhaust system, can someone remind me exactly where you’re supposed to point the temperature thingy? And what is the right temp range to be in? Quote Link to post Share on other sites
Island Time 1,235 Posted March 21, 2020 Share Posted March 21, 2020 That depends where you measure. Outboard of the water injection point should be warm, not hot. Where water comes out exhaust should be under 50deg, never hot enough to steam. Test must be done at full load, otherwise pointless. Also worth checking temp at thermostat housing, and each end of the heat exchanger. Quote Link to post Share on other sites
whitepointer 34 Posted March 23, 2020 Share Posted March 23, 2020 good idea to regularly check the raw water inlet fitting on the exhaust mixer, I had mine off recently, because of a bit of steam coming from exhaust, mine was half blocked with corrosion,, now water coming from exhaust is tepid, Quote Link to post Share on other sites
Island Time 1,235 Posted March 23, 2020 Share Posted March 23, 2020 Tepid is good! Quote Link to post Share on other sites
