armchairadmiral 411 Posted May 1, 2020 Share Posted May 1, 2020 Transom board of our inflatable has detached from its rubberised frame. Any advice on how best to repair and what glue to use ? Quote Link to post Share on other sites
chariot 242 Posted May 2, 2020 Share Posted May 2, 2020 Buy a new one. Quote Link to post Share on other sites
SanFran 12 Posted May 2, 2020 Share Posted May 2, 2020 I've gone through a few different tubes of glue. Don't cheapen out and only use one for pvc or hyperlon, whichever your tender is made from. Quote Link to post Share on other sites
Island Time 1,232 Posted May 2, 2020 Share Posted May 2, 2020 Bostic - get it from the glue guru in wairau rd... Works great. but as above, once one seam goes, the whole lot is suspect Quote Link to post Share on other sites
marinheiro 352 Posted May 2, 2020 Share Posted May 2, 2020 1 hour ago, Island Time said: Bostic - get it from the glue guru in wairau rd... Works great. but as above, once one seam goes, the whole lot is suspect and very difficult to get a good bond to weathered surfaces Quote Link to post Share on other sites
Island Time 1,232 Posted May 2, 2020 Share Posted May 2, 2020 Ive used this on PVC dinghies a bit. Cleaned with MEK first, bond was stronger than the PVC... Quote Link to post Share on other sites
Luigi Vercotti 7 Posted May 2, 2020 Share Posted May 2, 2020 Use the same glue that's keeping your wallet closed. It's seems to be pretty strong stuff, so should do the trick.😀 1 Quote Link to post Share on other sites
armchairadmiral 411 Posted May 2, 2020 Author Share Posted May 2, 2020 Thanks all especially Luigi.That's nice !. Unfortunately it seems you misunderstood. It's the wooden transom that's come away from the rubberised / PVC insert frame.The dinghy itself is in primo condition and what's happened is a glue failure. Thx IT. Quote Link to post Share on other sites
chariot 242 Posted May 2, 2020 Share Posted May 2, 2020 Had a similar problem a few years ago. Next thing the handles fell off. It was all down hill from there. That's why i suggested buying a new one. Quote Link to post Share on other sites
Ex Machina 365 Posted May 2, 2020 Share Posted May 2, 2020 1 hour ago, armchairadmiral said: Thanks all especially Luigi.That's nice !. Unfortunately it seems you misunderstood. It's the wooden transom that's come away from the rubberised / PVC insert frame.The dinghy itself is in primo condition and what's happened is a glue failure. Thx IT. Did exact same repair and it worked . Used the bostic with a special additive . Made sure transom was dry and sanded it back to fresh wood then sealed with epoxy . Use MEK to clean off old glue . Use care with MEK or you will end up growing a 3rd testicle ....or worse Quote Link to post Share on other sites
madyottie 82 Posted May 3, 2020 Share Posted May 3, 2020 I've been wondering the same thing. Left the deflated dink in the back of the car for a few days, pulled it out to find transom and handles coming unstuck. Oops. Quote Link to post Share on other sites
