Jacven 0 Posted May 13, 2020 Share Posted May 13, 2020 Hi Guys. I have a old cresta craft. While freshing up the inside over the lock down I found a purposeful hole in a box in section under the floor in the center of the boat at the back. The hole seems to be similar to the bung hole in the transom but inside the boat about 300mm in from the transom. The hole has a casing around it and it threaded. So my question is. What is it for and should it be plugged? Quote Link to post Share on other sites
Cliff Warne 0 Posted August 4, 2021 Share Posted August 4, 2021 Could I ask what motor you are running? I have a similar boat with a 70hp, but want to go bigger. Mine also has that hole, and I've plugged it up. Thanks Quote Link to post Share on other sites
Island Time 1,233 Posted August 4, 2021 Share Posted August 4, 2021 Plugging it is a bad idea. Its a drain hole...... Quote Link to post Share on other sites
Jockinnz 0 Posted December 28, 2021 Share Posted December 28, 2021 Hi guys, am looking at buying one of these. Do you have any idea of the weight? How does the 70hp motor perform? Did you end up going bigger, and what did you get if you did? Any advice is greatly appreciated. Thanks. Quote Link to post Share on other sites
whitepointer 34 Posted December 28, 2021 Share Posted December 28, 2021 Drain for the underfloor section Quote Link to post Share on other sites
