lateral
Heat resistant tape
aluminium tape, available from most trade suppliers, eg
https://nzsafetyblackwoods.co.nz/en/aluminium-foil-tape-1270?page=1&sortby=&minprice=0&maxprice=100&count=50
probably find it in Mitre 10 or Bunnings as well, but get good quality like Bear or 3M.
I stuck the soundproofing to the panels using 3M 4200, but any similar product or construction adhesive will work
Share this post
Cheers,  will go 3M for replacement.
Tried aluband a few years ago, not realizing how hot the EB got.
That was a mistake- all delam'd and a mess as it ate the foil on sound proofing.
Share this post
The box must not get too hot. Heat is bad for everything, The ALT will risk being cooked and most especially, it robs Hp if your engine has to breath it. Make sure you have good air flow through the Engine box.
Share this post
