Tamure
2 MFDs one nav card
Anyone set up a second plotter on their N2K network that uses charts from the first plotter? B&G Vulcan series. Other option is screen mirroring on an ipad but then theres waterproofing, sunlight readable and battery issues.
Share this post
No problem. Put the vulcan upstairs in the wet, and only use the tablet below, where its dry? What tablets does not make much difference, whatever you have is best. If your're buying one specifically for the boat, then a ruggedised  unit might be best, or even a lifeproof case. Trouble with the case is it isn't waterproof when charging...
Share this post
