Sign in to follow this
Bradz
Sail Drive Hull Boot
Hi All, we will be replacing our sail drive diaphragms in a few weeks. The question i cant seam to find any great information on is what product to use in gluing the new fairing boot with.
I understand the preparation to the hull and the rubber boot itself, however would like to know what adhesive products other have used.
Cheers.
Share this post
22 hours ago, ScarecrowR31 said:
I used a 2 pot product from the guy who makes dry suits in Wellsford. Its stuck on like the proverbial with no lifting on the front lip 2 years later. Maybe give him a call?
Dolphin drysuits
Share this post
5200 is otherwise known as "the devils glue" Its a bitch to remove, and will pull off a laminate before letting go quite often. I's use 4200 or similar for something I might want to take off.
On the saildrive fairing boot, you can remove the 5200 with a multitool and the scraper blade, as access is easy. You'd likely have to cut a hatch out....
Share this post
