Sign in to follow this
Marine Speakers
Cheers for all the replies guys. We must be lucky with the current Pioneers, they are mounted just below the winches and have lasted well with no feet going thru them. Still leaning towards the Fusions I think, will have a listen and decide from there.
Dan
Share this post
I don't know of any fully "waterproof" speaker. The only thing making any "marine" speaker a "marine" speaker, is that it has a plastic cone. The basket on all drivers I know of, are simply a lightly plated metal. To be truely waterproof, you would need the speaker fully sealed or made from SST. The cone should be able to take a splash of water, but not total immersion.
I use a pair of 6x9 Panasonics in the aft steering position and I took the metal mesh cover and sprayed it is a SST metal spray. They have been there for 3 years now and no rust. I did try Zinc as a primer and then a topcoat, but it didn;t last before rust spots appeared.
Share this post
In My experience..... Go with the cheapest you can get.
They all sound not particularly wonderful.
They will crap out in 18months regardless of spending lots vs little.
The Boss Speakers that were about are ok- if you get them cheap.
Would go with Fusion over Pioneer for the replacement face plates....if they were much the same price.
If your worried about sound quality- build a pod like Booboo's.
Share this post
And to be fair, it is always going to be a challenging environment - you are either underway, with the accompanying sounds of wind, sails, engine etc, or holding a gathering in the cockpit where the speaker will be blocked by someone's leg or back. And later doused with rum. Such is the life of a cockpit speaker.
I wish Booboo would post a photo of his big box on the Jagged though, just to illustrate what can be done. :thumbup: And whoever it was that had the pods mounted in the shrouds of their Piedy.
Share this post
If your worried about sound quantity- build a pod like Booboo's.
Just fixed that for ya :P
But otherwise yes; unless a speaker has a decent enclosure and a decent source i.e. reasonable amount of current from the head unit, or better yet - an amplifier (digital are much more efficient than traditional analogue amps) then the difference isn't huge, and even less so in a noisy outdoor environment.
Share this post
I've been reasonably happy with the 2x 6x9 in the back of Smokey- with 1200w of bridged amp stuck through them ;)
that is one thing I would reccommend if you have the battery power to cover it.....stick an amp in!! :twisted:
Share this post
yes agree, adding an amp makes a HUGE difference but you are right about the battery power, my stereo can draw up to 30amps depending on how many subwoffers are hooked up!
Attached a few shots of the box mentioned earlier, it has 2 x JVC 350w 6x9's and 2 sony explod 6.5's with crossovers and seperate tweaters. The speakers are non marine but they are cheap enough to replace every so often anyway, they have lasted 3 years now and have seen plenty of water and salt. I made sure i got the 6x9's with solid mesh covers as i figured that most of the water (only spray and rain) wouldnt go through it saving the speakers a bit. The covers have gone slightly rusty but not too bad and still pump out the sound. There is a partition between the 6x9's but nothing seperating the 6.5s from the 6x9s and i have found that they distort with the force from the bigger speakers anyway but even when not used they help to distribute the noise.
The new fusion speakers with the tweater in the middle and the more solid cover are about the best out there I reckon. The old ones with the crosovers and tweater were great for the sound but the tweaters rusted out real quick and the old covers broke way to easily.
Share this post
The system also works well in the van and can be loaded into a marina trolly and setup on the dock with a battery and a charger, its the way forward i reckon!
The only problem is you often end up with way too many people on you boat!
Share this post
Sorry MS, but there is no such animal. Turning 0's and 1's into o'sand 1's does not equate to louder sound. A "digital" amp is one of those snake oil machines.
Oh you guys, mere amatures.
How does 100Kw sound??? (insert Tim Toolman grunts)
Share this post
