sailing from mangonui to kerikeri inlet - tips?
dear all,
i and one other crew will be sailing from mangonui to the BOI, within the next two weeks. both of us have some experiences (i have been offshore several times) but we have not done this particular passage. it does not look difficult on the chart, but some of you may know better! so, what are some of the things to take note of? :roll: in particular,
1. can it be done in one day of moderate winds at this time of the year? (we are doing the trip on a 26-ft cruising yacht, new to us, and plan to embark at crack of dawn)
2. what is a good routing? are there "passes" that should actually be avoided? how far to stay from shore? should i steer north of all the islands en route?
3. is the route you recommend relatively free of semi-submerged rocks and boulders? (our boat draws 1.4 m)
4. if we break the trip into two legs with stopover in whangaroa, where should we anchor for the night? does the marina there cater to casual visitors? (we would prefer some safe anchorage near the mouth of the harbour.)
5. aside from whangaroa, are there "safe havens" en route?
6. what VHF channel to get weather for that part of the coast? any 3G signal reception possible? (i use telecom)
many thanks! joseph
Share this post
I'm not that familiar with the Cavallis ... certainly not as familiar as some on here so will leave discussion of that area to others.
Whangaroa Harbour is a fabulous, well protected harbor with plenty of safe secure anchorages close to the entrance or in any of the arms that lead off the main harbor The entrance to the harbor is lit at night and its fairly hard to find during the day just by eye (no problems with a chart plotter or chart and GPS though). There's good fishing inside the harbor if you anchor out, or if you want to get a marina berth there is a small marina at Whangaroa township. It doesn't look like a particularly flash marina, but there ya go. At Whangaroa itself, there's a pub and a shop and that's about it. Possible shelter depending on wind direction can also be had in the lee of Stephenson Island about 5 miles off the entrance to Whangaroa but there is foul ground around the island.
Banaari would be the Kerikeri Inlet expert .... sounds like he's personally sounded out some of the mudbanks lately. I'm sure there are others with plenty more to share about that piece of coastline.
Share this post
It is a pretty straight forward, basic seamanship applies, if you have a GPS, (handheld is good) you can plot your course to miss any rocks that are close to the direct route. Passing through (inside) the Cavalli's shortens the trip a little and is worth it, just to experience sailing in confined waters as you exit the southern channel, try and time it so the tide is in your favour. There is a rock that has caught several yachties out near the southern part of the Cavalli bay, GPS will show it or / and check it on a paper chart. It would be on your Starboard side. Or you can sail around the outside, keeping a reasonable offing to to have clear air if the wind is anywhere from the SW through West.
Make sure that the GPS is set to WGS84 so what you see on it is actually where you are. For those of us who have done it many times it is not a biggy, take it easy, plot your course carefully and mainly enjoy it.
Share this post
That's about the full and complete extent of my knowledge!! _IF_ your intentions in the Inlet include the Pickmere Channel and above, then it is most definitely tide-restricted... drawing 0.6 my current rule of thumb is 1/3 tide minimum and then proceed cautiously.
But I'd be consulting the likes of Bimini Babe, Sealegs, etc.
Share this post
hi everyone, many thanks for the advices. my destination is blacksmith bay past doves bay, where i have secured a legal mooring. also, in this part of the country, do they encourage people to call up the coast guard and let them know about a trip, and also call them when it's done? thanks. joseph
Share this post
Below radio info
Definatly do Whangaroa if you have time, and don't worry about a marina unless you need supplies as there are plenty of places to anchor
It's about 20 nm to Whangaroa then another 35 to Keri Keri aprox so it's doable in a little cruiser with a favourable breeze but it will make the trip if you stopover.
You will be in ph range the whole way
CG nowcasting
Location Channel
Doubtless Bay 20
Bay of Islands 21
Or CG on
Whangaroa 84
BOI 86
Far North Radio
VHF Channels: 60 East Coast,
VHF Weather Broadcasts: 0730, 1330, 1730 and 1930 on request
Share this post
Hey Joseph, google earth says 19 miles to whangaroa, 25 roughly into the cavalli islands area /general bay and 45 to moturoa island / kerikeri inlet, so that sounds like 2 comfortable legs or 1 longish day trip in a 26 footer to me.
The cavalli area is good in pretty well all winds and is lovely. Waiiti or horseshoe on the big Cavalli in maybe N but certainly NE to E, or hop over to the mainland in N through to SW or even south. Lots of bays there from mahinipua in the corner down to say matauri.
Particularly sneaky rocks? well, that one that Steve mentions around the cavallis, and the one off the Northern/western side of Moturoa that tends to catch a few boats.
You need to get a copy of the old RAYC cruising guide.
Share this post
that would be this?
COASTAL CRUISING HANDBOOK, Tenth Edition.
By Royal Akarana Yacht Club. Hardcover. 312 pages, 160mm x 230mm, black and white diagrams.
The Coastal Cruising Handbook is a comprehensive cruising guide to New Zealand’s coast and off-lying islands from North Cape to East Cape. Since the first edition was published in 1972, steady demand has indicated that this publication fills a very real need for the navigator in North Island waters.
This tenth edition, while remaining true to the spirit of the original and the intentions of the founding editors, has been extensively revised to take into account recent changes to buoyage and marine developments.
NZ$62.00 + delivery.
http://www.boatbooks.co.nz/cruznz.html
Share this post
thanks for the book link, which i visited. shown there is also this title:
NEW ZEALAND'S NORTHLAND COAST (new edition of - Northland Coast Boaties' Atlas; this is the second edition).
By David Thatcher. Hardcover, 297 mm X 210 mm, 192 pages, full coour photographs and charts.
Click here for a Java enabled browse through this book.
This is an entirely new edition, with the same hard cover, sewn binding and full colour as the Hauraki Gulf Boating Atlas - which is its companion volume. It is fully indexed, with 192 pages and considerable addition to content. The guide covers in detail the harbours and coastline from Whangarei to Cape Reinga, and the Three Kings Islands.
The section for Whangarei covers the marinas and details of the large water area from the Whangarei Heads to the Town Basin.
Coverage from there comprises Tutukaka and Whangaruru and the coast in between. The Bay of Islands section starts at Whangamumu and on its own is an extensive and invaluable guide to the region. Coverage includes the Waikare inlet and the extensive water area in the approaches to Kerikeri.
Thence coverage extends to the Cavalli Islands, Whangaroa and The Far North. For Doubtless Bay and northward, including the Three Kings Islands, much effort has gone into obtaining photos, narrative, charts and plans. This constitutes a unique component of this guide to New Zealand's Northland Coast.
As with the Hauraki Gulf Boating Atlas, in presentation and content this is a guide produced to the highest international standards and will make an excellent gift. NZ$82.00 + Delivery.
any comment about its quality? if i don't go cruising farther than whangarei, would this be a better choice? thanks. joseph
Share this post
Yes thats it, but I have much earlier editions. usually a tenner in second hand bookshops.That and Pickmeres atlas. I don't know anything about the later Thatcher books but I'm sure they're good.
that would be this?
Share this post
