  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
Tack ring has a hook.
From the tack down through a hollow vertical gooseneck pin,
at the base of the mast is a Harken wire cheek block (HA 309), round that,
Back up the mast about 1800mm to a second harken cheek block (HA 309).
on the end of that rope is a block (HA 308) setting up the first cascade 2:1
From the base of the mast up through that block with a second much lighter block (HA 304)on the end
setting up the second 2:1
Off that is a Harken triple block and becket at the bottom (HA 231), it has a little cam cleat built onto it,
aty the top is a harken triple (HA 228), giving 7:1
Total purchase 28:1
getting the first two cascades set to the right length is essential to get enough travel
Yes, exactly !
In a strong breeze with Carbon mainsail the harder you pull the cunno, the faster you go
Coupled with less mast rotation
Follow up question: What is keeping the sail up? Hook? Single/double halyard? What clutch?
Single, 8mm non-cover spectra halyard and Spinlock XT (XTS by today's nomenclature) here.
The halyard is sleeved for maximum clutch holding power. So far this has worked as intended.
/Martin (summer vacation starts today)
[Follow up question: What is keeping the sail up? Hook? Single/double halyard? What clutch?
Main Halyard is 8mm Superbraid (spectra) uncovered (cover starts just above where it goes into clutch),
2:1 head shackle is Tylaska H5
Clutch is Lewmar 2910 1208 (6-8mm)
I checked the boat and the cunno purchase is actually only 14:1, it has only got 1 of the cascades on it. But it is certainly plenty of purchase.
I take that is 8 mm including the cover.
I have up-dated my sketch:
/Martin
  • 2 weeks later...
or for those running a more budget style campaign they could use a "mylaska" available at all good marine stores :)
(also known as a shackle and a sheave)
