  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
a 40 m^2 mainsail on a 11.6m high mast with a Righting moment of around 3000kg/m equates to a main head load of 684 kg
How do you calculate that?
/Martin
Enter numbers into our RC calc sheets !
Or use AES 01 numbers!
Both are our Spar design tools.
Does that 'main head load' translate directly to actual 'load on the halyard' though? Wouldn't that formula be more a horizontal than vertical load. It may well do but I'm just struggling a little to see how. But I'm sure as apples no Albert Einstein.
Its the load at the head. If it is a 1:1 halyard it is also the load the halyard is under.
For what its worth Vincents numbers for TVS is 10ton on Main Haliard and 2.5 on the Cunningham and 9 on the Sheet.
Asuming he's ball park right, I would expect loosely pro-rata loads to righting moment for other multis?
