drbob 0 Posted March 15, 2014 Share Posted March 15, 2014 Am replacing an old Nilsson V3000 anchor winch w capstan - some external winch parts not working as desired. Before I give brass/bronze parts away for scrap, does anybody need parts for spare or repair? And, how the feck do I separate the main shaft from the external deck plate? I've got all the externals off the shaft, so all I have externally now is the deck plate with the shaft through it. Bolts between deck plate and gearbox have been removed. But I can'g get the gearbox and shaft to drop out from the deck plate. Should the gearbox drop off the shaft and the shaft lift out up through the deckplate, or should the shaft drop out down from the deck plate? Can't see anything on the old drawings from Nilsson suggesting which way to do things. I guess next step is to email Nilsson Link to post Share on other sites
drbob 0 Posted March 15, 2014 Author Share Posted March 15, 2014 Ah, found this doc on Nilsson site: http://www.jamesnilsson.com/files/docs/ ... ndlass.pdf which I think means it should all drop out from below after all the top gear is removed from the shaft. Link to post Share on other sites
wheels 544 Posted March 15, 2014 Share Posted March 15, 2014 The shaft should remain in the Gearbox and the entire Winchmotor/box with shaft drop down out of the deck plate. Link to post Share on other sites
white tornado 1 Posted March 15, 2014 Share Posted March 15, 2014 If it has a chain gypsy, I could be very interested in that. Otherwise, these go for quite good money on trade me. Link to post Share on other sites
drbob 0 Posted March 16, 2014 Author Share Posted March 16, 2014 got it apart managed to separate the gearbox, which took the off centre weight off it, then a bit of persuasion and out it came big hole in the foredeck, just in time for the rain bit munted really Link to post Share on other sites
marinheiro 367 Posted March 16, 2014 Share Posted March 16, 2014 if you have not already bought a replacement, it would be worth checking with Grant Nilsson about refurbishing yours. The V3000 is way over built compared to anything on the market now. Grant can make up new bits and can also fit a reversible motor as well, as long as the gear box is in good shape. I have one as well, 25yrs old and only needed the motor looking at after all that time. The motors are a modified Lucas starter motor so are of course a bit of a weak link...... Link to post Share on other sites
