Island Time 1,235 Posted November 20, 2014 Share Posted November 20, 2014 Now sitting in the car waiting for the Admiral. Does that mean you'll be ok now, or that you knew it was pin 5? Port settings are normally 4800bps, 8, none and 1. It is VERY unlikely you'll need to change the buffers etc. If you are stuck, tell me the make and model of the Gps and I'll give you the connections. Quote Link to post Share on other sites
erice 732 Posted November 20, 2014 Author Share Posted November 20, 2014 thanks for this coaching misremembered the pin number pin 5 was the one i was using , (1,2,3,4,5 top of serial plug, 6,7,8,9 bottom row) the nmea output from the garmin128 i think i have correct as i have the pinout and used it to connect the nmea to the vhf i'm suspecting the new super-cheap usb converter isn't working right...will see if i can test it somehow here at home Quote Link to post Share on other sites
Island Time 1,235 Posted November 20, 2014 Share Posted November 20, 2014 No problem. What version of windows? Does the usb-serial adapter have a red or yellow exclamation mark by it in device manager - or even maybe does not appear in device manager? When I'm on a pc again, rather than my phone, I'll give you the cable connections. Tomorrow. Quote Link to post Share on other sites
erice 732 Posted November 20, 2014 Author Share Posted November 20, 2014 32bit serial adapter for use on a winxp netbookj showing up fine in the device manager, no driver problems etc have found details of an adapter loopback test and will try it out tomorrow on the old netbook which i left on the boat have the adapter here but can't test it on this 64bit win7 computer if i can't nut it out tomorrow i may take you up on your offer Quote Link to post Share on other sites
Island Time 1,235 Posted November 20, 2014 Share Posted November 20, 2014 Most of the cheap adapters use the prolific chipsets. If it is older than the 2303 chipsets there are no drivers for 64 bit. Ok on your Xp though. Loopback test should tell you if it's working. Quote Link to post Share on other sites
Guest Posted November 20, 2014 Share Posted November 20, 2014 I had exactly the same issues a while back and it was the USB-serial converter. Need to spend a couple of extra bucks and get a goodie. I tried 4 and the most expensive worked. Funny that, I don't practice what I preach sometimes. Quote Link to post Share on other sites
erice 732 Posted November 21, 2014 Author Share Posted November 21, 2014 yup, not getting anything with the loop back test so may try taking it back for another one meanwhile, the heart transplant team has finished with the heavy work so next week is sewing up the arteries and getting back to beat Quote Link to post Share on other sites
erice 732 Posted November 27, 2014 Author Share Posted November 27, 2014 the last few days have been plumbing the new craftsman cm2.16, (mitsubishi 2LE) back where the vetus 2.06 (mitsubishi 2LE) used to be the vetus had the optional zf10m gearbox with 2.72:1 reduction ratio the craftsman (cheap new/old stock) came with the standard zf10m with 2:1 reduction ratio so to avoid changing the propellor the plan was always to keep the vetus box also had decided to try and use the still good, 2006, vetus; engine mounts, starter motor, control panel + looms...but the vetus loom's relay box didn't fit the holes on the slightly different craftsman bell housing, so used the new loom which meant also had to use the new alternator and control panel so the different plugs fit and then the new starter motor as well as the start relay piggy backed on top was 90degrees different to allow space for the bigger alternator's power terminals so in the end just the vetus engine mounts got reused wish i had just fitted the new engine straight as pulling all those bits off and then putting them, all back on when they didn't fit wasted a day or so and then when the engine wouldn't start i had messed with so many variables it took even longer to pull everything off again to check the loom and earths again etc Quote Link to post Share on other sites
erice 732 Posted November 30, 2014 Author Share Posted November 30, 2014 the start problem was that the starter wouldn't turn over suspected earths as could hear a relay chattering cleaned; loom -ve, battery to engine -ve and battery -ve terminal + cable faces still no turn after more pondering cleaned the battery +ve post, cable ends and terminal and the engine chugged into life not a moment too soon as in 3 hours vindil had to be off the mooring and at the finger wharf for a haul-out that was booked 3 weeks ago Quote Link to post Share on other sites
erice 732 Posted February 17, 2015 Author Share Posted February 17, 2015 :: boat coming along well, living the dream tonight's sunset at isslington bay still amazed that can web a pic while reading email at anchor (small screen phone connected to old xp notebook which will double as nav computer once connected to gps) Quote Link to post Share on other sites
erice 732 Posted January 31, 2016 Author Share Posted January 31, 2016 to round out this "beginner buys cheap old boat + discovers expensive problems " thread may as well add this engine start video from last year and some sailing videos all good 1 Quote Link to post Share on other sites
erice 732 Posted February 5, 2016 Author Share Posted February 5, 2016 back when looking to buy Vindil in 2014 had asked the DPO - dreaded previous owner - when the 2 jib + 2 mast winches had last been serviced the reply "lubed for life aren't they?" but after a year of my use the dry, high pitched ring from their ratchets kind of screamed that this wasn't so, + everything inside was very dry and needed grease first off, with a standard screwdriver, were the mast winch caps then a cir-clip, + off came the drum safely with with no springs or pawls firing off over the side so greased the spindles, the 2 pawl shafts and back then went together then the old base driven jib winches another simple slotted screw head and they gave up their guts to grease on the dry main spindle and pawl pivots on a roll now so next was the slightly more complicated 20? year old simpson - lawrence vertical, manual capstan stumped here with no screw visible so it was off to the net for the opening step now all back together, turning a tiny bit stickier with the grease and a little more muffled next year will probably do it all again (+ now know the little springs in the spare parts box are for the old swedish winch pawls) Quote Link to post Share on other sites
steven123 0 Posted November 29, 2023 Share Posted November 29, 2023 Hi can anyone confirm this is the same boat with replacement engine ?I saw this listing you may be interested in: Storfidra 25 with central Auckland City Mooring https://www.trademe.co.nz/4439576684 Quote Link to post Share on other sites
