Young Entertainer 59 Posted July 13, 2015 Share Posted July 13, 2015 Anyone one got any recommendations? So far it looks like a BEP unit. Want to be able to keep track of how much left mainly, and when batteries are fully charged Quote Link to post Share on other sites
Island Time 1,235 Posted July 13, 2015 Share Posted July 13, 2015 The BEP one works well, PROVIDED it is correctly programmed. Make sure you get the correct Perkets co-efficient from your batt supplier, so you can set it up right. It should auto-reset the capacity every time it is fully charged, so as it does not slowly get out of "sync" with the batts. I have had more than 10 years out of the house batts on Island Time, much, I think, to do with looking after the batts with the info provided by the monitor... Some people I've talked to reckon batt monitors are no good, but when you get down to it, mostly they are primitive models, or are incorrectly set up. I like them... Quote Link to post Share on other sites
Young Entertainer 59 Posted July 13, 2015 Author Share Posted July 13, 2015 and as a secondary question, budget is there now for either a smart charger and installation, or replacing the current lead acid batteries (which are 2 years old) with AGM batteries, which one do you think will be the best spend of the money? All this is leading up to eventually replacing an old electric fridge. So eventually will do it all but probably over 18months. Current alternator is a 60amp valeo somthing Quote Link to post Share on other sites
Battleship 100 Posted July 13, 2015 Share Posted July 13, 2015 I'm sure IT will chime in but my personal experience is AGM wont stand up to abuse as well as good lead acid batteries. If your lead acid are still good AGM wont necessarily be an upgrade. Are you talking smart charger via 240 volt or one on the alternator? Both are a good investment IMHO. Quote Link to post Share on other sites
Island Time 1,235 Posted July 14, 2015 Share Posted July 14, 2015 1st let me say I am not a Battery specialist, what I know comes from years of use and a technical interest only. Take or leave my ramblings as you see fit! I think that if the Alternator is internally regulated, or does not have a smart charger, then the biggest single improvement you can make is to fit a proper regulator - 3 stage, temp compensated. If the Lead Acid batts are ok, I'd leave them alone... Willow, I'm interested in your comments re AGM. The Batts in Island Time (now due for replacement) are over 10 years old, and they are AGM/Gel hybrid batts. I think that the main issue people have with batts, including AGM, is abuse causing premature failure. The abuse is usually incorrect charging voltages/procedures, and/or over discharge. Remember that for long life a batt should not be discharged more than 50%. It should be kept in a highly charged state. Read the manufacturers recommendations for charging voltages - don't guess, OR take ANYONES (except the manufacturer) word for the right voltage! If you do this you should get many years from your batts, AGM or Lead Acid, as far as I can see. It is common to see failures any time after about 2-3 years, or even less if there is a serious issue with use or charging. I really had good service from my AGM hybrids, including 3 years live aboard, and they are almost 11 years old now. It has only been in the last 6 months that the performance drop off has been noticeable. I have wondered if my use of the shore power (2 years now) system was the cause - if you have a smart charger (shore or alt), make certain that the voltage settings match the batts needs - not just he label, but check what it's actually doing! I'll soon be considering if I will replace these batts with the same type, or move to something newer - possibly lithium. When I get to that point, I'll post some stuff on here... Quote Link to post Share on other sites
Black Panther 1,584 Posted July 14, 2015 Share Posted July 14, 2015 I have had a full set of batteries die on an earlier boat after a long period on shore power. Often wondered if they were related. Quote Link to post Share on other sites
Farrari 4 Posted July 14, 2015 Share Posted July 14, 2015 I have always wondered about the benefits of Lithium-iron batteries vs. the additional cost. Claims of 10x the charge cycles, high power density and lighter weight are appealing. http://www.lithiumion-batteries.com/lithium-marine-batteries.php Quote Link to post Share on other sites
ScottiE 174 Posted July 14, 2015 Share Posted July 14, 2015 I've been wondering the same thing. I started researching this but decided I had other more basic boating demands to resolve first. Got as far as for calculating typical demands, storage and and charging requirements. But it does seem to me that you could get rid of the start battery and rely on one house battery, for my little demand anyway. The Li-Io batteries in Ferrari's link suggest that they are capable of both deep cycle usage down to 100% and CCA for starting. But sh*t they are expensive - setting up a battery system as IT describes, with vigilance, resulting in a 10 year life for a good battery would still be hard to beat. Quote Link to post Share on other sites
Island Time 1,235 Posted July 14, 2015 Share Posted July 14, 2015 Yeah, Lithium is good but expensive. Smaller, lighter, deeper cycle, but for me the real advantage would be charge rates - REALLY fast. Not sure I can justify the expense this time, but this next lot of batts is likely to be the last AGM hybrids - in another 10 odd years I bet lithium will be cheap! Quote Link to post Share on other sites
erice 732 Posted July 14, 2015 Share Posted July 14, 2015 i've got a pretty basic system of 2 gel house batteries (2nd hand 2yo? american MK mobility scooter batteries that had passed a discharge test) and a new lead acid car battery for starting the new 2cyl diesel the house batteries are kept topped up by 50watt solar regulated by a simple/ dumb marlec regulator that apparently charges to 14.4v. it has a 3 color led to show charge/regulate and house battery status the MK gel spec sheet says they are ok to charge to 14.6v but with engine running the voltmeter on the old furuno gps showed the alternator to be pushing out higher than that presumably ok for the lead acid start battery but not good for extended long life of the gel house batteries fortunately the boat also has a swedish septor dual battery separator that electronically splits and controls house batteries independently of the start battery this has a voltage trim pot which has allowed dropping the voltage coming from the alternator/start battery to a lower/healthier level for the gel house batteries to keep an eye on it all i recently installed a small voltmeter and a couple of press switches just inside the companionway mainly this is to tell me when the start battery voltage is dropping below the solar fed house batteries then i pop across some little jumpers Quote Link to post Share on other sites
Island Time 1,235 Posted July 14, 2015 Share Posted July 14, 2015 I'm not sure how accurate the Voltage reading on instruments are, but I would expect OK. To be sure I'd check them with a good multimeter. I'd just like to point out that the volts displayed on your instruments will be the voltage at their source of power - perhaps a distribution bus - this may not be the same as the batt voltage. It pays to check now and then that the voltage at your instrument or panel IS the same as at the battery terminals directly. Any discrepancy in voltage (normally lower!) is due to resistance in the cables and connections between the measurement point and the batts. This is usually corroded terminals in the joins between, but can be damaged or undersized wiring. The MAXIMUM allowable voltage drop to any device being powered is 5% - so 0.6v on a 12v system. A lower voltage will draw more Amps, so minimising voltage drop is desirable. It is really important for a battery meter to accurately measure the volts of the batt. 10ths of a volt (or even less) are very important, so the meters normally (as does the BEP one mentioned) have a calibration function, so you can set their display to match the ACTUAL voltage at the bats. If you do this then their calc of battery state of charge will be more accurate. Quote Link to post Share on other sites
erice 732 Posted July 14, 2015 Share Posted July 14, 2015 will check the voltmeter with the fluke and paint a couple of spots of green + red paint on the glass Quote Link to post Share on other sites
Battleship 100 Posted July 15, 2015 Share Posted July 15, 2015 IT re the AGM, Not a big deal but my last 130 ah AGM only lasted a year and a half before it wouldn't power the instruments for more than 3 hours. I'll be the first to admit it had a hard life being on a boat that was used for mostly racing at the time, by the end of the RNI it was stuffed. After a bit of research popular opinion (not necessarily scientific fact) backed up what I was experiencing in that they don't cope with being severely deep cycled as well as good quality lead acid. I know all batteries will die an early death with harsh treatment but I have had better performance out of car batteries than the AGM. Li-ion seems to be the magic bullet once the price comes down lets hope so. Supercapacitors anyone? Quote Link to post Share on other sites
erice 732 Posted July 15, 2015 Share Posted July 15, 2015 ^ 1 year's pretty poor what make AGM and how was it charged? The leading advantages are a charge that is up to five times faster than the flooded version, and the ability to deep cycle. AGM offers a depth-of-discharge of 80 percent; the flooded, on the other hand, is specified at 50 percent DoD to attain the same cycle life. As with all gelled and sealed units, AGM batteries are sensitive to overcharging. These batteries can be charged to 2.40V/cell (and higher) without problem; however, the float charge should be reduced to between 2.25 and 2.30V/cell (summer temperatures may require lower voltages). Automotive charging systems for flooded lead acid often have a fixed float voltage setting of 14.40V (2.40V/cell), and a direct replacement with a sealed unit could spell trouble by exposing the battery to undue overcharge on a long drive. http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm Quote Link to post Share on other sites
Island Time 1,235 Posted July 15, 2015 Share Posted July 15, 2015 Yeah erice, in that instance I'd suspect the charging, or possibly using it until it's flat. It is possible to kill a battery very quickly from abuse. Are you abusive Willow?? Quote Link to post Share on other sites
Battleship 100 Posted July 15, 2015 Share Posted July 15, 2015 Very abusive Like I said it was flogged mercilessly, sometimes (often) when your tired whilst racing you forget to run the engine to charge the batteries. I won't name the manufacturer as it wasn't their fault but believe that lead acid is tougher when abused. Quote Link to post Share on other sites
erice 732 Posted July 15, 2015 Share Posted July 15, 2015 ^ any solar? Quote Link to post Share on other sites
Battleship 100 Posted July 15, 2015 Share Posted July 15, 2015 No solar while racing, bashing upwind for days on end tends not to be conducive to having the solar panels hanging off the side we fit them whilst cruising. Quote Link to post Share on other sites
marinheiro 352 Posted July 15, 2015 Share Posted July 15, 2015 Another option for a battery monitor is this from Blue Sea https://www.bluesea.com/products/1801/Vessel_Systems_Monitor_VSM_422 I selected it because it can monitor DC and AC with a single instrument (BEP's cannot do this)plus it has the tank gauge and other options. I also have separate ammeters on the outputs of both alternators, very Handy to see what they are up to. You can purchase NZ made ammeters and voltmeters from Carel-Electrade http://www.carrel-electrade.co.nz/ They were OEM suppliers to BEP in the 80's and my original gauges function perfectly Quote Link to post Share on other sites
marinheiro 352 Posted July 15, 2015 Share Posted July 15, 2015 consumption somewhere between 0 - 0.1 ahr Quote Link to post Share on other sites
