Zozza 293 Posted November 14, 2016 Share Posted November 14, 2016 Hey guys, how do I firstly get the sludgy stinky diesel and water out of my bilge that has accumulated? It is below the level of the bilge pump down there (it's a full keel deep bilge - must be a good three to four feet deep or more there under the cockpit where it has accumulated). I was thinking drill pump? Any better ideas than that? And, once I pump it out, what should I clean it with? Just a general detergent? Cheers for any thoughts on this. Quote Link to post Share on other sites
erice 732 Posted November 14, 2016 Share Posted November 14, 2016 cup into bucket finish with sponge til just oily sludgr sticking to sides next day (to see if you have leaks) dishwash deteregent on sponge to wipe of sludge rinse in bucket with clean water with a little deteregent if no dish detergent use laundry powder detergent is detergent, wraps up oil molecules then dry with rag how have you plugged the prop shaft hole? Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Hey Eric, just duct taped of the shaft hole for the moment. Cup into bucket? I do not have 4 foot long arms, and even if I did, that would take an age, Quote Link to post Share on other sites
Kevin McCready 83 Posted November 14, 2016 Share Posted November 14, 2016 First use the special absorbent pads which remove the oil and diesel like magic from the surface. Then ... good luck Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Already tried both the pads and the sausage like things. Both hardly made a dent, plus squeezing them was messy as sh#t. I am looking for a more, well, "powerful and quick" option to get rid of it all - there is a lot. Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Just went and took pics of bilge...it's a deep dark place down there..... Quote Link to post Share on other sites
Ed 143 Posted November 14, 2016 Share Posted November 14, 2016 Wet and dry vacuum cleaner, or for smaller volumes one of those vacuum engine oil extractors. Quote Link to post Share on other sites
erice 732 Posted November 14, 2016 Share Posted November 14, 2016 hope it's not in the water with only duct tape holding back the flood if its out of the water pull off the tape stick some garden hose up the prop shaft hole position at deepest point give yourself some good length outside and suck a syphon Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 hope it's not in the water with only duct tape holding back the flood if its out of the water pull off the tape stick some garden hose up the prop shaft hole position at deepest point give yourself some good length outside and suck a syphon Definitely out of water. On cradle, in my driveway. Quote Link to post Share on other sites
Kevin McCready 83 Posted November 14, 2016 Share Posted November 14, 2016 Set up a siphon. Don't swallow. Quote Link to post Share on other sites
Island Time 1,227 Posted November 14, 2016 Share Posted November 14, 2016 vacuum oil extractor; http://www.trademe.co.nz/motors/boats-marine/parts-accessories/engine-parts/auction-1200297974.htm Quote Link to post Share on other sites
wheels 543 Posted November 14, 2016 Share Posted November 14, 2016 Wet and dry vaccy is brilliant. I'd go by a cheapy. Always a very handy thing to have on hand. Erice is correct about dishwashing detergent. It works really well. But one I use a lot because I get great results from it is Klenco which is a yellow container from Supercheap. It's an excellent detergent on Oils. It has Alkaline Salts that help break down the Oil/grease sludgy gunge that tends to build in the bottom. I have not tried it, but have been told simple green have a product that is supposed to work well. Quote Link to post Share on other sites
rmiker 15 Posted November 14, 2016 Share Posted November 14, 2016 Vacuum Oil extractor as above.. They work an absolute treat for jobs like that. My last chore for mine was to vacuum all the rubbish out of my diesel tank as it was very conveniently constructed with no drain This however let me leave the tank installed for cleaning. Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Seems like it is a contest between this: http://www.trademe.co.nz/home-living/cleaning-bins/vacuum-cleaners/commercial-vacuums/auction-1199285453.htm And this: http://www.trademe.co.nz/motors/boats-marine/parts-accessories/engine-parts/auction-1200297974.htm Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Wet and dry vaccy is brilliant. I'd go by a cheapy. Always a very handy thing to have on hand. Erice is correct about dishwashing detergent. It works really well. But one I use a lot because I get great results from it is Klenco which is a yellow container from Supercheap. It's an excellent detergent on Oils. It has Alkaline Salts that help break down the Oil/grease sludgy gunge that tends to build in the bottom. I have not tried it, but have been told simple green have a product that is supposed to work well. Kenco, no 'l'...this stuff Wheels? http://www.supercheapauto.co.nz/Product/Kenco-Heavy-Duty-Degreaser-6-Litre/343954 Quote Link to post Share on other sites
Zozza 293 Posted November 14, 2016 Author Share Posted November 14, 2016 Hell yes. After I blew up the Wa's new one that was only an hour old by sucking fibreglass sandings I brought a $69 Ryobi, it's been magnificent for wet and dry. Highly recommended for the discerning Man Cave. At the same time I brought the Wa a new one as well....and now stay well clear if it. A stainless wet n dry, that's a little sexy. I'd do that before the oil extractor. That wet and dry stainless one is cheaper too than the oil extractor. However, how "safe" are these wet 'n drys? Can handle that dirty, oily bilge water ok? Quote Link to post Share on other sites
wheels 543 Posted November 14, 2016 Share Posted November 14, 2016 Thanks for a correction Partisan.Wet and Dries are safe. But taking the quality slightly further, if you go to Godfreys, ask them for their one that has a "bypass" motor. I forget the name (damn I am really struggling with memory lately) it starts with P I think. Anyway, a Bypass motor means it gets it's own cooling air, rather than the air being sucked through the fans then going through the motor. This stops the motor from sucking dust and most importantly water, should it ever over fill. Where as all the others use very sucky motor air to cool the motor. There cleaner is no more expensive than the likes of the Repco/Supercheap/M10 units and in some cases, is actually cheaper. Quote Link to post Share on other sites
Ed 143 Posted November 14, 2016 Share Posted November 14, 2016 Thanks for a correction Partisan. Wet and Dries are safe. But taking the quality slightly further, if you go to Godfreys, ask them for their one that has a "bypass" motor. I forget the name (damn I am really struggling with memory lately) it starts with P I think. Anyway, a Bypass motor means it gets it's own cooling air, rather than the air being sucked through the fans then going through the motor. This stops the motor from sucking dust and most importantly water, should it ever over fill. Where as all the others use very sucky motor air to cool the motor. There cleaner is no more expensive than the likes of the Repco/Supercheap/M10 units and in some cases, is actually cheaper. Pullman is the one you are thinking of. If its on a cradle in the drive way then real quick and nasty solution is to drill a hole and let it drain out, wash it out then fill the hole with a bit of thickened epoxy.... I can understand if this would not be a preferred option Quote Link to post Share on other sites
ex TL systems 63 Posted November 14, 2016 Share Posted November 14, 2016 just use your garden hose to siphon it out, you don,t need to suck to start it flowing , just run water in from the tap then disconnect and water will flow out as long as the end is lower than the bilge, Then you can clean and flush it a few times. Quote Link to post Share on other sites
Muzza 18 Posted November 14, 2016 Share Posted November 14, 2016 otherwise try a drum pump with a long stem on it 3 to 4 ft should suck up ok once the lift required becomes over 2.5 metres most pumps won't lift. From the looks of the picture the boat appears to be fibreglass so you should be able to get away with washing out with Enviroclean which goes through oil like like last nights curry passes through the system. Enviroclean is a lot stronger than Simple Green.. Quote Link to post Share on other sites
