madyottie 82 Posted February 28, 2017 Share Posted February 28, 2017 On Sunday, in quite light winds, our furling kite basically unwound itself from the top end. The bottom end stayed rolled but no matter how much line I pulled, the top still flapped about, even after I had several wraps of sheet around the lower part. Is this a symptom of insufficient luff/halyard tension? Or am I missing something obvious? Also, is it common practise to leave the furled sail up, or drop it to the deck once furled? I noticed the rig tended to pump a bit going through boat wakes with it hoisted, which seemed less obvious once dropped. That said, I think I need to tighten the shrouds a bit. Thanks. Quote Link to post Share on other sites
RushMan 31 Posted February 28, 2017 Share Posted February 28, 2017 Fractional or masthead? Quote Link to post Share on other sites
madyottie 82 Posted February 28, 2017 Author Share Posted February 28, 2017 Masthead. Mast is ridiculously over size so I doubt there's any flex there. Quote Link to post Share on other sites
Clipper 343 Posted February 28, 2017 Share Posted February 28, 2017 For performance, take it down. Heaps of drag having it up there. Was it wrll furled in the first place? Is the rope/cable bit a non torsion one? Quote Link to post Share on other sites
Kevin McCready 83 Posted February 28, 2017 Share Posted February 28, 2017 Did you unfurl the whole lot and start again? Quote Link to post Share on other sites
madyottie 82 Posted February 28, 2017 Author Share Posted February 28, 2017 Was already: furled as wind had shifted forward too far. About ten mins later just the top started to unroll, while the bottom stayed still. It has a stiff line inside the luff tape. First furl may not have been that flash but nothing obvious flapping about. Bottom quarter had rolled really tight. In past life I've only had bags or chutes, so this furling thing is brand new, hence the luff tension question. I did try to furl again but it wasn't really working so just dropped it in the end. Quote Link to post Share on other sites
Ed 143 Posted February 28, 2017 Share Posted February 28, 2017 Unless you have a foil, the bottom is always going to furl tighter than the top. You just have to accept you'll need to drop it shortly after furling Quote Link to post Share on other sites
RushMan 31 Posted March 1, 2017 Share Posted March 1, 2017 Keeping some leech tension during the furl might help Quote Link to post Share on other sites
Clive 13 Posted March 5, 2017 Share Posted March 5, 2017 furl it downwind. Quote Link to post Share on other sites
