Tazzy Devil 18 Posted July 13, 2017 Share Posted July 13, 2017 Just getting a newly acquired Ross 930 ready for Cat 3 and was wondering how the securing of washboards and hatch bit is checked off, any easy tricks for doing this. Currently the washboards are a 3 piece set-up and simply slide in. Any quick easy ideas? Quote Link to post Share on other sites
ricka 3 Posted July 13, 2017 Share Posted July 13, 2017 Low down cleat or tube / jammer thing on the inside and another on the outside low down- length of cord goes from one cleat over wash boards and down to the other cleat- can be opened from inside and out and is adjustable for 1 to 3 boards Quote Link to post Share on other sites
Deep Purple 511 Posted July 13, 2017 Share Posted July 13, 2017 What he said Quote Link to post Share on other sites
Frickie 9 Posted July 13, 2017 Share Posted July 13, 2017 That is pretty much how mine is set up too. Quote Link to post Share on other sites
jay 3 Posted July 13, 2017 Share Posted July 13, 2017 To secure the washboards I have a small hole in top washboard with a cord passed through and knotted outside. Line then just stretches over a little hook inside that can be reached from either inside or outside when the top hatch is open. To secure the top sliding hatch, there is an inexpensive special purpose clasp fitting that can be operated from inside or outside that is sold by marine stores, in either plastic if you are weight obsessive, or metal. My cat 3 inspector a few years ago had never seen this fitting and thought it was pretty neat. Quote Link to post Share on other sites
Island Time 1,220 Posted July 14, 2017 Share Posted July 14, 2017 Mine is a bit different. Both washboards are attached with short lines and small carabiner type clips, on the inside. The lower one has barrel bolts to fix it into the companion way sides if required. The top one locks into the hatch slide with a commercial deadlock, able to be operated from either side. Quote Link to post Share on other sites
Sail Rock 28 Posted July 14, 2017 Share Posted July 14, 2017 To secure the washboards I have a small hole in top washboard with a cord passed through and knotted outside. Line then just stretches over a little hook inside that can be reached from either inside or outside when the top hatch is open. To secure the top sliding hatch, there is an inexpensive special purpose clasp fitting that can be operated from inside or outside that is sold by marine stores, in either plastic if you are weight obsessive, or metal. My cat 3 inspector a few years ago had never seen this fitting and thought it was pretty neat. Quote Link to post Share on other sites
Sail Rock 28 Posted July 14, 2017 Share Posted July 14, 2017 Hi Jay. Any chance you could provide a picture of the special purpose clasp fitting that you mentioned? I am looking for a similar solution for my companionway hatch. SR Quote Link to post Share on other sites
Tazzy Devil 18 Posted July 15, 2017 Author Share Posted July 15, 2017 Thank everyone, used the rope over the top trick. Got Cat 3 , ready for the coastal! 1 Quote Link to post Share on other sites
jay 3 Posted July 16, 2017 Share Posted July 16, 2017 Here's a picture of the hatch clasp I use. A number of the marine shops sell these. If you search google for "flush pull latch nz" you should find sources. Quote Link to post Share on other sites
S.M.U. 15 Posted July 16, 2017 Share Posted July 16, 2017 HOM43001-WH from fosters. I used this brass one from them and it worked great with a small hole drilled thru the washboard DW4120CP Quote Link to post Share on other sites
