GBE fore beam replacement
Nothing but tumbleweed and the whistling sound of the wind on this topic.  You probably need to make the topic name "Carnage from broken fore beam.." and then commence your post with "... is what will happen if no one suggests a decent supplier."
On a serious note, is it worth starting a topic called, "Suggested suppliers for maintaining/improving 8.5 multis" where us newcomers could get suggestions as to who the "go to" people are for sails, rigging, tramps and the general wizardry for setting up our GBEs and similar?
I like this suggestion.
I replaced my forward beam a year ago with whatever Urlich had - I recall they only had 1 that fitted/was the correct diameter.
Whatever you do make sure you put in a compression tube from the forestay back to the mast. Essentual if you want to really load it up with anything off the prod. Stiffens the whole platform and much easier to do now.
I replaced the main beam in mine which was a real ass of a job.
  • Upvote 1
Sourced a beam from Sparloft industries. Then Me and crew replaced the beam a few weeks ago. Was super easy, kept the boat floating at the beach, slid out the old and in with the new.
Looking forward to putting up a bit more sail and having some fun!
Well I'm learning slowly... My new-last-year forward beam has cracked with about 50mm left intact.  I hadn't sleaved it, which I think is the primary issue.
I've asked John/Sparloft for a quote.
Bugger, bugger, bugger.
I had this problem when my Spyder was almost new. We didn't crack the forebeam. We 'only' bent it -- beafed it up and then bent it again. Other Spyders in Europe have broken beams so clearly a weak point with this design.
In 1989 I re-engineered the crossbeams from the ground up together with a friend and that was that.
/Martin
Watching the old GBE forebeam use to always scare me when beating upwind in a blow and chop.  Doing the same yesterday in the T made me very pleased about the size of the forebeam - very very stiff.  Now I just need a bum clean and some decent sails to really make her hum upwind.
We put Freedom's old square top main on and have been having quite a bit of fun but we've had a couple of lumpy trips lately and it's been working pretty hard.  It is quite alarming the amount of movement in a GBE that's considered 'normal'.
I was replacing mind proactively ( hadnt seen cracks but had broken back beam) and as i undid the last bolt it buckled in front of my eyes due to seagull striker tension. It was well f&cked and the last sail i had we had been giving it death, nearly hull flying with masthead kite. After that i kept a very close eye in things...
i'd agree it's the lack of sleeving that did it
on multis all those wracking loads are at the corners
and the strength there needs to be at least double the mid-beam
so with alloy beams you can either use a simple section, that's far too strong-heavy in the middle
or find a way to get double or triple the strength at the ends
any bicycle with pretensions of light weight - high performance uses butted tubing for exactly that reason
carbon ones would tend to have 4 - 5x the carbon at the corners than at the middle
when capricorn was out we found that after 10? years of thrashing there some minor cracking around the rear beam to float join
nothing on the front, presumably as the front beam is twice as thick so spreads the loads better
ground off the bog
and laid down lots of carbon in all directions, over a much bigger area
but yeah, alloy beams that aren't telegraph poles in the middle
are going to need to be about twice as strong at the ends somehow
sleeving being the obvious solution
sure you're getting far better advice from others but you could buy the same beam extrusion and sleeve it with 1mtr? bits of the broken beam that had a correctly sized 1mtr section cut from them
the problem would be compressing them down
or you could cut these 1mtr sections of the old beam in half to use as half molds, wax the inside, and glass in a few mm of boat cloth 1 mtr long, half-cure with the tubes strapped shut and some blown up wine bags against dry? cloth? forcing the wet cloth to shape, then deflate and remove bags to lay 900mm carbon strips inside that, half-cure again with the bags, lay more 700mm carbon, half-cure 600mm etc
try and bake your final mold  on a the dash of a closed up car on a hot sunny day, (reaches about about 50C), all day
crack them open the next day to remove your glass insulated carbon sleeves, ready for sanding rough, latering in an epoxy, adhesive mix and slipping into new beam ends
not going to be quick or pretty but the end result won't be seen and can be as strong as you want it
start begging carbon scraps
Not sure where you found cracks, and apologies if stating the obvious, but you need to ensure the stainless straps do not touch the ali at all or the corrode out real fast. I sleeved my front beam when i did it, prick of a job to get them in there. So when i did my main beam, i got john at sparloft to sleeve for me.
