Island Time 1,211 Posted January 13, 2018 Share Posted January 13, 2018 Thinking I might go in there tomorrow. Anyone with local knowledge? Is it OK for a yacht 1.8m draft, and if so, anything I should know about the channel? Quote Link to post Share on other sites
Island Time 1,211 Posted January 13, 2018 Author Share Posted January 13, 2018 If you get some pics km, they can easily be Geo referenced and used as a chart overlay in opencpn.... I decided not today, NE. I'll wait for something with W in it, and yep, go in slow using a fwd scan sonar.... Quote Link to post Share on other sites
Priscilla II 377 Posted January 13, 2018 Share Posted January 13, 2018 Quote Link to post Share on other sites
Black Panther 1,568 Posted January 13, 2018 Share Posted January 13, 2018 I have seen boats that took a hard right at the entrance and tucked up into the trees Quote Link to post Share on other sites
Bogan 8 Posted January 14, 2018 Share Posted January 14, 2018 Problem with Whangateau is the lack of good anchoring space. You can follow the channel by following the line of moorings, but there's not much room left for anchoring except a small area right up at the tip of the spit on the west side - which isn't very sheltered. Tides aren;t an issue for most of the boats that moor there. The water's really clear and you can see the entrance channel pretty well from deck level. Quote Link to post Share on other sites
Bad Kitty 249 Posted January 14, 2018 Share Posted January 14, 2018 Entrance is fine unless it's a really good easterly & swell. Don't cut the corner outside the entrance, there are rocks to the NE of the stbd mark. Motor up thru the moored boats & take the channel to the south toward the wharf & boat ramp. I'd anchor just past the moored boats in the gap before the second lot of mooring up by the wharf. Pretty crowded once you get up there. Reasonably strong tidal movement, maybe 2 knots? Holding is good though. Quote Link to post Share on other sites
Black Panther 1,568 Posted January 14, 2018 Share Posted January 14, 2018 Minimum depth? Quote Link to post Share on other sites
Bad Kitty 249 Posted January 14, 2018 Share Posted January 14, 2018 Bottom photo of KM's, bottom right of frame under the strut that holds the wing on is where I mean to anchor. Much further than that and there's a whole lot more moored boats, & it will shallow up. I think you'll be ok at 1.8, tricky bit is every tide change you'll swing 180 & fall back the other way in the channel. Quote Link to post Share on other sites
