Steve 34 Posted May 14, 2019 Share Posted May 14, 2019 Someone smarter than me will have the answer. Let’s say you wanted to save some weight. Starter battery is around 20 kilos I suppose. A little jump starter about 1. Why not just swap one for the other? Charge it with a USB connection like you do with a phone and as long as the motor generally starts easily then what’s the problem? Quote Link to post Share on other sites
w44vi 17 Posted May 14, 2019 Share Posted May 14, 2019 If your after weight reduction with your battery go lithium ion. Depending on how big your motor is you maybe able to use a motor cycle battery Quote Link to post Share on other sites
wheels 543 Posted May 14, 2019 Share Posted May 14, 2019 Jump starters are just baby Gel batteries and are not capable of giving any log term cranking ability. If it doesn't start first try, you are stuffed. Diesels, especially when Cold and a little worn, need a good turn over period to build compression high enough to fire. So a decent Start Batt is needed. Quote Link to post Share on other sites
Steve 34 Posted May 14, 2019 Author Share Posted May 14, 2019 But if your motor always starts first click? If not I guess you could link the house batteries. I suppose there's one more fly in the ointment. The bloody anchor winch. But if you were getting all anal about a particular regatta then one small house battery and a jump starter would suffice? Hell of a lot easier than taking off the toilet seat, the cupboard doors, the squabs and the speakers. We did all that (and more) for the RNI one year and it was amazing how much of a pile of gear we ended up having to store. Hundreds of kilos but really only compensated for all the extra palaver required for cat 2. Quote Link to post Share on other sites
Sudden5869 17 Posted May 15, 2019 Share Posted May 15, 2019 Yeah I thought about Lithium ion for starter battery last year. I think Lithium ion batteries require a complete Battery Management System. Without that you may not comply to regs, insurance coverage etc.... Happy to be corrected. Quote Link to post Share on other sites
harrytom 642 Posted May 15, 2019 Share Posted May 15, 2019 Hand crank?? 1 Quote Link to post Share on other sites
mcp 32 Posted May 15, 2019 Share Posted May 15, 2019 Jump starters are just baby Gel batteries and are not capable of giving any log term cranking ability. They are usually Lithium Polymer, also commonly known as LiPo. Of the mainstream lithium ion chemistry batteries, these are the highest energy density and also the most likely to fail and go into thermal runaway. They are very sensitive to being balance charged correctly. They will deliver amazing amount on Amperage instantaneously at C ratings of up to 95C or more, which make them perfect for the jumpstart application. They are also the reason for the recalls of a number of smart devices that spontaneously combust. I would not keep one of these on a boat. Go have a lookie around youtube and google for Lipo fires. Also someone above mentioned Lithium Ion. Just to be clear, this is a line of multiple different types of battery chemistry and not one type. For automotive or marine, you want to use a lithium Iron Phosphate or LiFePo4. This is because it is one of the safer chemistries [safer in my opinion than flooded lead acid] and also because its nominal voltage and full charge voltage more closely matches the lead acid type equipment found on most boats and vehicles. So fully charged at 3.65v per cell = 14.6v at 4s and a nominal voltage of 12.8 - 13.2. The cobalt & manganese types are 4.2 volt fully charged, so 12.6 at full at 3s and 3.6 nominal, so 10.8 at 50%. So they don't work easily with normal 12v systems. On my boat, I am going to install Lead Carbon [not to be confuse with lead crystal] from a reputable company [There is good and bad lead carbon] or maybe LiFePo4. But probably Lead Carbon. Quote Link to post Share on other sites
Island Time 1,234 Posted May 15, 2019 Share Posted May 15, 2019 Agreed. Lead carbon looks pretty interesting. Quote Link to post Share on other sites
Dtwo 157 Posted May 15, 2019 Share Posted May 15, 2019 Yes they do require management gear std flooded lead don't. But that gear is not for YNZ or insurance as such, it's more to stop you blowing your boat up or even worse blowing your own arse up. As Boeing and a few others have found if these lithium's go bad and dump all they energy out that can happen inside a millisecond with massive and disastrous results. I was told if that happened with mine all my wiring could literally vaporise. No idea if that is true or just a wise person trying to scare me away from playing in there. My battery has 13 wires coming off it that go to many assorted black boxes that go click and thunk. LifePO4 isn't going to blow anyone up, exciting as it may sound. Using it in a boat vs a car environment means that the rates of current draw and the size of the bank itself is hardly scratching the surface of what they can provide - which means an inherent safety margin of some magnitude. You really don't want to drop a spanner across the bank though. The battery management systems exist more to safeguard the batteries from low or high voltages, which will quickly kill your bank. Basically a wallet protection system. As for Boeing, which knob told them that putting batteries in a fuel tank was a good idea? Quote Link to post Share on other sites
Crazyhorse 47 Posted May 15, 2019 Share Posted May 15, 2019 Combined with decompression leavers (if you have them?) Quote Link to post Share on other sites
wheels 543 Posted May 15, 2019 Share Posted May 15, 2019 Jump starters are just baby Gel batteries and are not capable of giving any log term cranking ability. They are usually Lithium Polymer, also commonly known as LiPo. Not the larger plastic carry case type. We recycle them at work. You are possibly referring to those teeny weeny packs not much bigger that a cell ph and you plug into the Ciggy lighter Quote Link to post Share on other sites
wheels 543 Posted May 15, 2019 Share Posted May 15, 2019 As for Boeing, which knob told them that putting batteries in a fuel tank was a good idea? Nope, someone is pulling your leg. They sit in the Tail section where the APU is situated. Quote Link to post Share on other sites
mattm 98 Posted May 15, 2019 Share Posted May 15, 2019 I’d say he means more like this wheels. Which attaches to the battery. This one claims to be lithium cobalt, 24000mAh, 1000a peak current. It also has USB and a cig socket, as well as a light, I mention this, as interestingly, the specs say it can fully charge an iPhone 10 times, or jump start up to 40 motors ???? My work van battery died a sudden and total death two weeks ago, starter gave barely a click, I jump started it with this four times that day, 2.7l petrol, as well as a customers 500hp diesel, with a battery flat enough it would crank only for a moment, and charged my phone for a while. The pack still showed 3 from 5 lights worth of charge. My work van started faster with the dead battery and this than it does a new, oversized start battery. I wouldn’t use it as the start battery on the yacht alone, but I can hand start mine if I wanted to save weight that badly anyway. Quote Link to post Share on other sites
wheels 543 Posted May 16, 2019 Share Posted May 16, 2019 I have always been amused at the use of mA for such things when it should really be A. They simply want to make the thing look impressive to the many that would have no clue what an A or mA actually was. 20,000 of them sounds really impressive, where as 20A not so. Although 20A is still a fair bit of wack, it just doesn't sound as impressive.Reminds me of the Getto Blasters that have figures of 2400WPMPO. Wow!!! Sounds impressive. Quote Link to post Share on other sites
Crazyhorse 47 Posted May 16, 2019 Share Posted May 16, 2019 I have always been amused at the use of mA for such things when it should really be A. They simply want to make the thing look impressive to the many that would have no clue what an A or mA actually was. 20,000 of them sounds really impressive, where as 20A not so. Although 20A is still a fair bit of wack, it just doesn't sound as impressive. Reminds me of the Getto Blasters that have figures of 2400WPMPO. Wow!!! Sounds impressive. "Candle power" is the same when it comes to some Chinese light makers claims! Quote Link to post Share on other sites
Freedom GBE 27 Posted May 16, 2019 Share Posted May 16, 2019 The mah for these things are at 5 volts which fooled me. Bought a 12000 mah one from burnsco on special, still pricy, thinking it would be twice as good as our cheap 5ah battery. It kept turning of, It stopped working after 4 months and was glad to return it. Quote Link to post Share on other sites
mcp 32 Posted May 19, 2019 Share Posted May 19, 2019 You are possibly referring to those teeny weeny packs not much bigger that a cell ph and you plug into the Ciggy lighter Yes sir, that is what I was referring to. Quote Link to post Share on other sites
ballystick 72 Posted May 23, 2019 Share Posted May 23, 2019 I have a small pack, a little smaller than the above picture. It is a Lithium Cobalt type ($100) which is supposed to be the worst. It is amazing, jumpstarted my boat (Yanmar 40 hp) and many cars in the Marina carpark. It sruggles when there is a completely flat battery so if you wait for around 20 secs it usually succeeds. Also, it charges up cell phones and devices. There is a warning not to leave it connected for over 10 seconds after starting and I think that is the most dangerous thing to do as far as I can see. It is rated to 300A so I used my clamp meter to measure the current and it definitely produces at least 150A which I thought was amazing, the short leads would reduce the usual cable resistance found in the cheap Repco leads. Handy to keep in the car and also, to give to the children for their own cars to save on breakdown charges. Quote Link to post Share on other sites
