El Toro 97 Posted July 19, 2019 Share Posted July 19, 2019 Has anyone got any thoughts on these bad boys? Am thinking of replacing my califont. Looking for hot water use only Cheers https://www.heatspace.co/store/p645/5kW_Premium_Diesel_Water_Heater_Kit_-_Eberspacher_D5W_SC_.html Quote Link to post Share on other sites
wheels 543 Posted July 19, 2019 Share Posted July 19, 2019 They have some great advantages, but do be aware they they don't just instantly turn on and off like the Gas Califont does. The unit has a start up procedure, then takes a certain amount f time to get to full heat, then has a shut down procedure. So the difference is that it has a Hot water storage facility to give you the instant hot water part. Quote Link to post Share on other sites
marinheiro 352 Posted July 19, 2019 Share Posted July 19, 2019 It will heat hot water but you will need a separate hot water cylinder ideally with a heating coil, similar to an engine heated cylinder (see Calorifiers in the parts and accessories section). These heaters are designed foremost for cabin heating by circulation though radiators Quote Link to post Share on other sites
Stray Cat 7 Posted July 19, 2019 Share Posted July 19, 2019 Has anyone got any thoughts on these bad boys? Am thinking of replacing my califont. Looking for hot water use only Cheers https://www.heatspace.co/store/p645/5kW_Premium_Diesel_Water_Heater_Kit_-_Eberspacher_D5W_SC_.html Hi Tom, we’ve just done the business on the Stray Cat. Have sent you a PM with Clyde’s phone number. Quote Link to post Share on other sites
splat 55 Posted July 20, 2019 Share Posted July 20, 2019 Double check that unit is covered by warranty in marine application Quote Link to post Share on other sites
Bad Kitty 249 Posted July 20, 2019 Share Posted July 20, 2019 We've got one on Bad Kitty, as said, it heats the hot water cylinder, so it's not like a califont. But love it, and if you're doing it then I'd add a heater or two, makes the boat warm & dry in the wet or winter. Quote Link to post Share on other sites
El Toro 97 Posted July 21, 2019 Author Share Posted July 21, 2019 Great thanks all Quote Link to post Share on other sites
