SSANZ 2020 Lewmar Triple Series
Is the start line moving from the Northern Leading area this year? Easier for Westhaven boats?
THE START
  1. 8.1  Races will be started using RRS 26 with the warning signal made 5 (five) minutes before the starting signal.
  2. 8.2  The Start line will be in the Waitemata Harbour
Under any level greater than one we were informed that the start had to be performed from on shore or with a very small crew from onboard a start boat.
Hence the Waitamata Harbour start line stated in the Notice of Race
Now we are in Level one and could end up in zero or even back in level two, it’s our intention to return to Northern Leading as this allows us to avoid shipping movements in the main channel
Planning this event under uncertain levels has been challenging to say the least
The Sailing Instructions are not out yet as we want to get into as stable as possible position re Covid Levels. Sailing Instructions will take precedents over the NoR.
The major change that will effect all from previous years is the starting format, there will only be three starts now at 10 min intervals. The starts will be in reverse order from the past with small boats away first then Shorthaul followed by long haul last. The start line will be longer than previous with the SSANZ buoy laid mid way forming two starting areas (Alfa and Bravo) divisions/classes will be advised of there start area in the SIs.
The other significant change is the finish line will be moved from Orakei to Resolution Racing buoy. A decision on finishing the third race in Islington Bay will be made the week prior to this race.
These changes are being made to facilitate racing in a difficult time with less exposure and risk to all involved
Please work with us to make this the great event it always has been.
Jon Henry
Race Director
SSANZ
With a lone entry in Baltic 1 so far! Was hoping for a bit more life there as I'm planning to be in it next year.
There are a heap of cheap older boats people could get in to to start racing there, have those interested just moved on to bigger things?
Is there a typo in the Notice of Race?
Lewmar Doyle Sails Short Course: Start passing Rangitoto Island (starboard), Shearers Rock Buoy (starboard), Haystack (Orapapa) Island, Motuihe Island (starboard), Browns Island (port), Motukorea Buoy (starboard) to the finish (approx. 39nm)
Since it does not state which side to leave the Haystack, we can effectively ignore this mark of the course! 😉
Some of the buoys we race around are unlit.  One has been destroyed.
Weekly Local Navigation Warning Summary Monday 22nd June 2020
WAITEMATA HARBOUR
Waitemata - The Devonport eastern inner cable mark (F.R) Int no. 3765.1 has been reported
as unlit.
Waitemata - The Yellow Special Mark buoy off Westhaven (Fl.Y.5s) has been reported as
unlit.
Waitemata - The outer Bayswater channel port-hand beacon (Fl.R.3s) Int no. 3770 has been
reported as unlit.
Waitemata - The Emu Rock South Cardinal (VQ(6)+LFl.15s) Int no.3845.25, has been
destroyed. A temporary lit buoy has been placed beside the rock.
Waitemata – The inner Yellow buoy off the eastern end of Whangaparaoa Peninsula (Q.Y)
has been reported as unlit.
Waitemata – The outer Yellow buoy off the eastern end of Whangaparaoa Peninsula
(Fl.Y.3s) has been reported as unlit.
Waitemata – The Hobson Bay Port hand beacon in charted position 36° 50.78S 174°
47.95E has been temporarily positioned at 36° 50.75S 174°47.91E. Final position will be
advised in due course.
Waitemata – The Northcote Mooring area SE Port hand beacon in charted position 36°
49.64S 174° 45.37E has been temporarily positioned at 36° 49.60S 174°45.33E. Final
position will be advised in due course.
Sailing Instructions will be out shortly and they will correct a couple of things.
NOR Rule 1.7. If there is a conflict between this document and the Sailing Instructions then the Sailing Instructions will take precedence.
Due to the changing times we are living in with Covid we have deliberately left publishing the Sailing Instructions as late as possible as things can change.
Another one is the start won’t be in the Waitamata Harbour, but in the usual place in the vicinity of Northern Leading.
Thanks for that.   In previous years there was only one combined NOR/SI.
Looking forward to the SI's so we can find out where the start and finish lines are, what the starting order is, what colour flag we need to buy, and radio sched details, and what the divisions are.
Regarding Shearer Rock buoy, old charts used to show a round buoy, plus an eastern cardinal mark in the same area.
On the latest chart, the round buoy has gone, leaving just the East cardinal mark.
Cardinal mark is the rounding mark at Shearer Rock
only 3 starts
0900 all divisions sailing Baltic course
0910 all divisions sailing PIC course
0920 all divisions sailing Doyle’s course
start line will be at Northern Leading
finish line will be at Resolution Racing Buoy
position reporting will be done by text
plus lots more so a good read of the Sailing Instructions, plus attendance at the briefing will be a must.
126 entries so far, don’t miss out.
  • Upvote 1
