Dtwo 157 Posted October 28, 2020 Share Posted October 28, 2020 I'm having a set-to with Simrad. I'm trying to automate the process of making a DSC call to a selected AIS target on my plotter. Simrad plotter, Simrad VHF, AIS from a Vesper XB-6000. Simrad "help"desk has been less than useful. They don't understand what their own gear is advertised as doing and can't answer simple questions. If you can understand what has been typed. They say that Vesper isn't compatible, although it is NMEA certified and provides all the relevant data to the NSS9 Evo3 plotter. Vesper support have been excellent and agreed with my layman's guess that the plotter should be generating the PGN for the DSC call, as it is the device which knows which target I'm trying to call. Simrad says the AIS should be transmitting the PGN. Simrad HD advised I was missing PGN#12908. That doesn't exist. They said refer to the manual, which specifies PGN#129808. That doesn't exist either. I suggested tit was supposed to be PGN#12808 - DSC Call Information. My question is - does anyone know how this stuff works? I'm guessing the only answer is a software fix on the plotter to output the correct PGN but I can't get any sense out of the freakin' edjit at Simrad. Telling him he was talking crap probably didn't help either.... Quote Link to post Share on other sites
Island Time 1,235 Posted October 28, 2020 Share Posted October 28, 2020 Well, the issue is that there is currently no standard for this function. Navico and the other manufacturers will use the non Navico device as an excuse not to help. Several manufacturers (incl Simrad) can do it using proprietary sentences with their own gear, but NMEA 2000 is a closed standard, and to be a member with approved gear the manufacturers have to sign a non disclosure contract. None of them will tell you how to do this. So, your best bet is likely signal K (Open source standard) or Kees - https://yachtelectronics.blogspot.com/ kees@keversoft.com. He may know. Again, he may not tell you. The easiest way at this point is to stick with one manufacturer - so change your AIS. I know that is a shame, as the Vesper is a great unit. The only real way to do this would be to get a Simrad system that does work, and record the sentences generated, then reverse engineer. Which is a breach or your user agreement for the Simrad MFD. I do agree that the MFD should be (and does on all the navico systems, incl Simrad) generating the PGN to make the radio call. Quote Link to post Share on other sites
Island Time 1,235 Posted October 28, 2020 Share Posted October 28, 2020 So which Simrad Radio do you have? What software is on it? Is your NSS evo3 on SW version 20.1? It needs to be. I might be able to sort this out, but no promises... Quote Link to post Share on other sites
Island Time 1,235 Posted October 28, 2020 Share Posted October 28, 2020 Oh, and PGN 129808 is for an INCOMING DSC call, and is what allows the plotter to show that - like a distress signal etc in the correct location. There is as yet no defined PGN for outgoing, as mentioned above. Simrad use a proprietary one, PGN 130816. See also https://mt.panbo.com/2015/04/direct-dsc-vhf-calls-to-ais-targets-a-nmea-2000-standard.html Quote Link to post Share on other sites
Fogg 427 Posted October 28, 2020 Share Posted October 28, 2020 From this I’d say IT knows his stuff! Quote Link to post Share on other sites
Dtwo 157 Posted October 29, 2020 Author Share Posted October 29, 2020 Yeah, thanks IT! I am staggered to find the official NMEA PGN list is incorrect and has been for 10 years now! That Panbo link is awesome - relieving to see others have gone down exactly the same rabbit hole and had similar conversations with Navico support. Sad to see that the post was 5 years ago and the same problem still exists. I'm pretty confident I'm on V20.1, although I'm doing a road trip in the South Island at present so not 100%. Will check. The VHF is an RS20, as recommended to me by Bay Marine Electronics. I spelt out what I was trying to achieve and even quoted the Simrad manual about compatible DSC radios. They aren't replying to my emails. Happy to listen to any recommendations. I'm reluctant to spend yet more money on electronics, I have had a bad run with buying sh*t that either doesn't work or doesn't do what is advertised. Quote Link to post Share on other sites
Island Time 1,235 Posted October 29, 2020 Share Posted October 29, 2020 OK, A couple of basic questions first. Sorry if this is too basic, but have you programmed your MMSI into the RS20? DSC wont work without it. Have you tried a manual DSC call and made certain that that is working. What software version is on the RS20? - it displays that briefly on startup. I had a play with a B&G setup today, worked fine. It was a B&G Vulcan MFD, and a B&G RS60B radio (Built in AIS transponder). The call button is present on the bottom of the AIS info list for any AIS target on the MFD. Press that and it says "do you want to make a call to MSIXXXXXX on ch70" Press yes, and away it goes. As far as I can tell, only the MFD and the radio are involved in the call, but I'd have to record the N2K data to be certain. So it SHOULD work on a Simrad MFD and Radio with current software if properly configured. Quote Link to post Share on other sites
Island Time 1,235 Posted January 27, 2022 Share Posted January 27, 2022 Released today; RS20S v2.30 and RS20 v1.28 New software for the RS20S and RS20 VHF radio is now available. This release incorporates a number of fixes and improvements as follows: RS20S: Add ability to initiate a DSC call from an MFD (via NMEA 2000). Add PGN129539 (GNSS DOPs) Add system GPS STATUS and SYSTEM DIAGNOSTICS Add support to change channel by the MFD Add long press up/down key on handset/fistmic for fast text scrolling Improve the sea and inland mode functionality Improve the radio backlight control by MFD functionality, Add the PGN65291 Improve EU ATIS functionality Improve speaker control, Internal and External setting and add persistence Update Australian VHF channel bank Set the Wx channel to CH10 when switch to inland mode in EU region Show ATIS ID at startup and in My VHF; add model name to My VHF Change the call sign from 12 digits to 7 digits Various other improvements and bug fixes RS20: Improve the sea and inland mode functionality Improve EU ATIS functionality Improve speaker control, Internal and External setting and add persistence Update Australian VHF channel bank Set the Wx channel to CH10 when switch to inland mode in EU region Show ATIS ID at startup and in My VHF; add model name to My VHF Various other improvements and bug fixes Quote Link to post Share on other sites
