SanFran 12 Posted March 4, 2021 Share Posted March 4, 2021 Have to remove it to replace an oil feed line to upper cylinder. I'm thinking Just a couple of bolts, unless anyone can wise me up. Older buhk 20. Quote Link to post Share on other sites
aardvarkash10 954 Posted March 4, 2021 Share Posted March 4, 2021 disaconnect the battery at the battery before everything else. the live supply to the starter should be connected to a stud on the starter solenoid - be gentle loosening it. Hold the cable firmly, and gently remove the nut. If it won't turn, use your normal sprays and potions to get it to release. Starter should just unbolt (un-nut?) from the bellhousing. Quote Link to post Share on other sites
marinheiro 352 Posted March 5, 2021 Share Posted March 5, 2021 might be an idea while it is off to take to the local autoleccy for an overhaul Quote Link to post Share on other sites
SanFran 12 Posted March 6, 2021 Author Share Posted March 6, 2021 Cheers for that. New knowledge. Quote Link to post Share on other sites
