ballystick 72 Posted May 13, 2021 Share Posted May 13, 2021 My boat came with a califont which is usually a no-no these days, so I fitted a rectangular 16 litre Isotemp hot water cylinder with tempering valve and 240V supplementary and that has been a bit too small if too many showers are taken but I also had limited space. I also fitted shut-off valves at the engine inlet and outlet just in case there is a problem with the hoses or heater to allow for normal engine operation. Subsequently, I fitted 2 valves to allow for califont operation when selected when the hot water runs out. Quote Link to post Share on other sites
Fish 0 Posted May 13, 2021 Share Posted May 13, 2021 I am feeling completely out of touch with all of this plumbed hot water stuff. Where do you guys shower on the boat? How can it be 'sailing' if you have all the mod cons of your house? Typically, I use a facecloth and some hot water (from the kettle) to wash the sunblock and salt crust off at the end of the day. We've used a solar shower to great effect in the past, but it's also just as easy to use a plastic water bottle and squirt yourself down with fresh water. This is a good way to rinse off after a swim. If we want a good wash, then some sailors soap / salt lather stuff, followed by the water bottle squirt down. The big issue for me is the water conservation. We have 240 l on board. Can't have a very long holiday if you shower in the damn stuff! Before you know it, you'll all have pressure water systems as well, and be pouring water down the drain every time you turn the tap on. Nothing like a little foot operated pump to get just the water you need... 1 Quote Link to post Share on other sites
Young Entertainer 59 Posted May 13, 2021 Share Posted May 13, 2021 totally agree about the water conservation, when i had a 1020 with pump water and a kettle to heat a bit up when we wanted it i family of 4 did 3 weeks on 160L (standard 1020 tanks), now i have 300 litres and pressure hot water we made it 4.5 days this xmas, problem is once you have it, it is hard to take it away 1 Quote Link to post Share on other sites
Kick Ass 47 Posted May 13, 2021 Share Posted May 13, 2021 We currently have 200L on the 1050 and get about 8 days. We have pressure hot and cold water and 2x showers, 1 inside and 1 on the transom. Before our next big cruise we will be expanding to 500L so we don't have to find water. We have a 25ltr approx hot water cylinder and if the whole family is going to have a shower we will run the engine at the same time to keep water warm which also tops up batteries. We have 2 adults and 2 kids. Quote Link to post Share on other sites
Black Panther 1,584 Posted May 13, 2021 Share Posted May 13, 2021 I make 120l per hour. 1 Quote Link to post Share on other sites
aardvarkash10 959 Posted May 13, 2021 Share Posted May 13, 2021 2 hours ago, Fish said: We've used a solar shower to great effect in the past, I have quickly learnt that standing bollocks-naked under a solar shower in the cockpit is a good way for me to clear an anchorage of bothersome other boats. I also now know why its call a cockpit. Quote Link to post Share on other sites
aardvarkash10 959 Posted May 13, 2021 Share Posted May 13, 2021 12 minutes ago, Black Panther said: I make 120l per hour. leaky old-man bladder? Quote Link to post Share on other sites
Black Panther 1,584 Posted May 13, 2021 Share Posted May 13, 2021 That's how i keep watch at night 1 Quote Link to post Share on other sites
Dtwo 157 Posted May 13, 2021 Share Posted May 13, 2021 We have 450l and that lasts 2 of us about 6 weeks. And I shower every night. What do you guys do with all that water - drink it? Quote Link to post Share on other sites
gisywaterboy 3 Posted May 13, 2021 Share Posted May 13, 2021 Does any one have any hacks for super simple warm water off the engine? Im not talking hot steamy shower, I'm thinking just rinsing salt off the kids at the end of the day, out in the cockpit, while the engine is running. There must be some clever, simple systems out there. I have a 2gm20F. Quote Link to post Share on other sites
Fish 0 Posted May 13, 2021 Share Posted May 13, 2021 2 hours ago, aardvarkash10 said: I have quickly learnt that standing bollocks-naked under a solar shower in the cockpit is a good way for me to clear an anchorage of bothersome other boats. I also now know why its call a cockpit. Have you tried taking your solar shower downstairs when using it? I understand all these plumbed hot water showers are used downstairs? PS, I have many other responses, none of which are appropriate even for a forum Quote Link to post Share on other sites
aardvarkash10 959 Posted May 13, 2021 Share Posted May 13, 2021 Just now, Fish said: Have you tried taking your solar shower downstairs when using it? I understand all these plumbed hot water showers are used downstairs? what, and take the fun out of it? Quote Link to post Share on other sites
Fish 0 Posted May 13, 2021 Share Posted May 13, 2021 14 minutes ago, aardvarkash10 said: what, and take the fun out of it? Do you have any daughters? Uni aged? Quote Link to post Share on other sites
funlovincriminal 162 Posted May 13, 2021 Author Share Posted May 13, 2021 1 hour ago, gisywaterboy said: Does any one have any hacks for super simple warm water off the engine? Im not talking hot steamy shower, I'm thinking just rinsing salt off the kids at the end of the day, out in the cockpit, while the engine is running. There must be some clever, simple systems out there. I have a 2gm20F. Wind a copper pipe around your heat exchanger and plumb tank water to one end and a cockpit shower into the other? Quote Link to post Share on other sites
aardvarkash10 959 Posted May 13, 2021 Share Posted May 13, 2021 7 minutes ago, Fish said: Do you have any daughters? Uni aged? nope. Past that stage. In reality, we typically solar shower in hte cockpit, but I'm decent enought to wear budgie smugglers when I'm doing it. The solar shower tied to the backstay. We can get two long-ish showers out of one solar shower bag and we got into the habit of having two bags on the deck each day. Quote Link to post Share on other sites
funlovincriminal 162 Posted May 13, 2021 Author Share Posted May 13, 2021 5 hours ago, Young Entertainer said: family of 4 did 3 weeks on 160L (standard 1020 tanks), now i have 300 litres and pressure hot water we made it 4.5 days On the 830 we would go to the barrier for 10 days with 3 x 20L plastic cans of fresh water, had a hand pump ib the galley and that was it. Half way through the trip was shower day, 2 adults and 2 small kids could get a quick shower each sat in outboard well with a 10L paint bucket, topped up over a jug full of boiled water using a 12v submersible pump with a solar shower hose and head on it. Blaardy luxury! Quote Link to post Share on other sites
Black Panther 1,584 Posted May 13, 2021 Share Posted May 13, 2021 If you have a daughter with curly hair triple all calculated amounts ( and clear the shower drain daily).. Quote Link to post Share on other sites
Fish 0 Posted May 15, 2021 Share Posted May 15, 2021 On 14/05/2021 at 9:06 AM, Black Panther said: If you have a daughter with curly hair triple all calculated amounts ( and clear the shower drain daily).. You must have been releaved when your daughters got their mother's looks Quote Link to post Share on other sites
Black Panther 1,584 Posted May 16, 2021 Share Posted May 16, 2021 And brains 1 Quote Link to post Share on other sites
