O_Smiladon 4 Posted July 14, 2021 Share Posted July 14, 2021 Hi guys, just Refurbished and repaired these winches. Now that I have everything backed to what it should be I have to put them all back together what sort of grease do you guys use to pack it all with is it something special or is it just normal grease grease Quote Link to post Share on other sites
ex Elly 197 Posted July 14, 2021 Share Posted July 14, 2021 Lithium grease on the drum. 3-in-1 oil on the pawls and teeth (no grease). Quote Link to post Share on other sites
O_Smiladon 4 Posted July 14, 2021 Author Share Posted July 14, 2021 6 minutes ago, ex Elly said: Lithium grease on the drum. 3-in-1 oil on the pawls and teeth (no grease). Cheers mate, What are the pawls ?? Sorry first time into a winch Quote Link to post Share on other sites
aardvarkash10 950 Posted July 14, 2021 Share Posted July 14, 2021 3 hours ago, O_Smiladon said: Cheers mate, What are the pawls ?? Sorry first time into a winch the pawls are the little teeth that stop the drum from spinning backward. Quote Link to post Share on other sites
marinheiro 352 Posted July 14, 2021 Share Posted July 14, 2021 12 hours ago, aardvarkash10 said: the pawls are the little teeth that stop the drum from spinning backward. pawls are pesky little spring loaded components that love to make a leap for freedom into the tide when you lift the drum off the shaft🤣 4 Quote Link to post Share on other sites
O_Smiladon 4 Posted July 18, 2021 Author Share Posted July 18, 2021 On 14/07/2021 at 3:42 PM, ex Elly said: Lithium grease on the drum. 3-in-1 oil on the pawls and teeth (no grease). Why not put grease on the gears ?? I would have thought load the sucker up with grease. Oil would just run out and all over the place. Thanks Guys Steve Quote Link to post Share on other sites
Black Panther 1,581 Posted July 18, 2021 Share Posted July 18, 2021 The grease gets thick and full of gunk over time. Then the pawls jam open and your crew gets a broken wrist. Quote Link to post Share on other sites
O_Smiladon 4 Posted July 19, 2021 Author Share Posted July 19, 2021 1 hour ago, Black Panther said: The grease gets thick and full of gunk over time. Then the pawls jam open and your crew gets a broken wrist. Copy that... Cheers guys Steve Quote Link to post Share on other sites
