marinheiro 352 Posted August 4, 2021 Share Posted August 4, 2021 Posting this to maybe help others avoid this problem on the Yanmars and other engines with aluminium body heat exchanger/exhaust manifolds. This is my Yanmar 4JH4E A few months ago I noticed salt crystals forming around the forward HEX end cap and and when pulled apart this was the situation and yet the rear one is just about in perfect condition What is noticeable is that the corrosion is on the part of the face between the clamping bolts. Will need to check if the face of the cover plate is dead flat. Hoping that Rocke can work his welding magic on this, otherwise it will be new one from USA -already priced it up. James Mobberley at Moon Engines recommends setting up a fresh water flush for these engines, a tee and a valve on the salt water intake. Had a look at a friend's 75hp Yanmar, and we could see signs of salt crystals, then he mentioned that his alternator had been damaged by salt water. 1 Quote Link to post Share on other sites
waikiore 398 Posted August 4, 2021 Share Posted August 4, 2021 James is right on these late model Yanmars with no anodes an occasional flush of the salt side with fresh is a sensible move. Quote Link to post Share on other sites
Fogg 427 Posted August 5, 2021 Share Posted August 5, 2021 How old and how many hours? Quote Link to post Share on other sites
harrytom 642 Posted August 5, 2021 Share Posted August 5, 2021 Being a sealed system, heat exchanger separate to normal cooling, why would you not have fresh water in there with a rust/corrosion inhibiter? Just like car with alloy heads Quote Link to post Share on other sites
marinheiro 352 Posted August 5, 2021 Author Share Posted August 5, 2021 1 hour ago, Fogg said: How old and how many hours? The engine is 16 yrs old, but has only been in service 6 yrs, 1000hrs. The more i look at this the more I am convinced this was a manufacturing/assembly defect. When the weld repair is machined they will ensure all parts mate perfectly. If you have a Yanmar, have a good look around those end caps - noting the turbo versions have a quite different heat exchanger Quote Link to post Share on other sites
Fogg 427 Posted August 5, 2021 Share Posted August 5, 2021 Ok will take a look. Mine is the turbo (700hrs). Quote Link to post Share on other sites
Island Time 1,232 Posted August 5, 2021 Share Posted August 5, 2021 1 hour ago, harrytom said: Being a sealed system, heat exchanger separate to normal cooling, why would you not have fresh water in there with a rust/corrosion inhibiter? Just like car with alloy heads Because it's a heat exchanger, one side is fresh, one side is salt (raw) to allow the heat exchange. This issue is common on these engines and the D series Volvo Pentas. The manufacturers say this is why they are insistent on the right coolant in the fresh water side, and that it is changed at the correct interval. It's also important to ensure that the models with electrically isolated sail drives are, in fact, still electrically isolated! There is a plastic gasket, and plastic inserts/washers on the saildrive mounting bolts for this reason. Quote Link to post Share on other sites
marinheiro 352 Posted August 5, 2021 Author Share Posted August 5, 2021 5 hours ago, Island Time said: Because it's a heat exchanger, one side is fresh, one side is salt (raw) to allow the heat exchange. This issue is common on these engines and the D series Volvo Pentas. The manufacturers say this is why they are insistent on the right coolant in the fresh water side, and that it is changed at the correct interval. It's also important to ensure that the models with electrically isolated sail drives are, in fact, still electrically isolated! There is a plastic gasket, and plastic inserts/washers on the saildrive mounting bolts for this reason. Beta and Nanni and just about everyone else use the same concept Beta: Nanni notable that they both use 3 bolt end caps compared to the Yanmar's 2 bolt. Maybe they figured out these are a problem. The guys at Moons said they believe all the European assembled marine engines source their Heat Exchanger/Exhaust manifolds from an Italian OEM supplier, Mota. Fogg's turbo Yanmar is different, those are assembled in Japan c.f mine which came out of Yanmar's Netherlands factory. Quote Link to post Share on other sites
Vivaldi 53 Posted August 6, 2021 Share Posted August 6, 2021 On Vivaldi there is a hose fitting on the suction side just after the sea cock for the salt water inlet. We can shut off the salt water side and run fresh through it which is pretty handy for the occasional rinse out. 1 Quote Link to post Share on other sites
marinheiro 352 Posted August 6, 2021 Author Share Posted August 6, 2021 14 hours ago, Vivaldi said: On Vivaldi there is a hose fitting on the suction side just after the sea cock for the salt water inlet. We can shut off the salt water side and run fresh through it which is pretty handy for the occasional rinse out. That's exactly what James Mobberly recommends, he also suggests using one of the salt removal products, eg Saltaway. Said he was not so keen on Barnacle Buster, has found it is too aggressive and has caused problems with seals, gaskets etc. He did highlight you need to be using some sort of container to hold the fresh water and let the salt water pump suck it into the engine via a hose to the Tee you mention. Some people have plumbed up direct fresh water hose connections to the downstream side of the salt water pump and this has resulted in flooded engines Quote Link to post Share on other sites
Vivaldi 53 Posted August 6, 2021 Share Posted August 6, 2021 2 hours ago, marinheiro said: That's exactly what James Mobberly recommends, he also suggests using one of the salt removal products, eg Saltaway. Said he was not so keen on Barnacle Buster, has found it is too aggressive and has caused problems with seals, gaskets etc. He did highlight you need to be using some sort of container to hold the fresh water and let the salt water pump suck it into the engine via a hose to the Tee you mention. Some people have plumbed up direct fresh water hose connections to the downstream side of the salt water pump and this has resulted in flooded engines Yeah you don’t want to pressurise it. The hose I use has a T fitting just after the tap that allows pressure water to run to waste. The water pump sucks what it needs and the flow can be adjusted with the tap Quote Link to post Share on other sites
Fogg 427 Posted August 7, 2021 Share Posted August 7, 2021 On 5/08/2021 at 7:50 PM, marinheiro said: Fogg's turbo Yanmar is different, those are assembled in Japan c.f mine which came out of Yanmar's Netherlands factory. Thanks. Do you know if that makes mine any better or still equally susceptible? As usual, other people know more tech info about my boat than I do… Quote Link to post Share on other sites
marinheiro 352 Posted August 7, 2021 Author Share Posted August 7, 2021 2 hours ago, Fogg said: Thanks. Do you know if that makes mine any better or still equally susceptible? As usual, other people know more tech info about my boat than I do… you need to look around where the 2 arrows are, especially on the underside, sorry cannot find a rear view of the engine. at the front look between the alternator and the hoses above it. even if you do not see any salt leakage, I would suggest if the engine is more than 5 yrs old as preventive maintenance, you should be taking the end caps off, checking the seals and sealing surfaces and getting the heat exchanger tube bundle cleaned, the last especially seeing as your yacht has come from a warm water environment. If you have any doubts I am sure IT would check it out for you 😄 Quote Link to post Share on other sites
Fogg 427 Posted August 7, 2021 Share Posted August 7, 2021 Yes IT loves it when I add to his to-do list… Quote Link to post Share on other sites
Makassi 0 Posted February 13, 2022 Share Posted February 13, 2022 Hello there. I hold a 4JH3-E 9.000 hours, 1997, 25 year old. No leak, but bad looking. The water passing into the exchanger IS salty. The water around the exchanger is cooling water, no salt, but extra protectives product. Thank you, Paul. Quote Link to post Share on other sites
wheels 543 Posted February 14, 2022 Share Posted February 14, 2022 Wasting ones time trying to flush the engine with fresh water, unless you can hook up a hose and run it for 15 min to half an hr. Even then, it may not flush the salt out. Especially if the Salt has worked it's way up into the gap between two mating surfaces. The thing to do is to remove the end cap. Make sure the seal is doing what it should. If the surfaces have become pitted, then have them filed, or machined(depending on how bad, clean and flat. Re seal it with a smear of selant between the gasket and surfaces. The issue is caused by Salty moisture being absorbed by the gasket. Hence why a simple flush will not be sufficient. The Gasket has created a gap between the two surfaces. Once corrosion begins, which it can due to all sorts of complicated reasons, there is just enough galvanic action to then allow it to continue and increase the damage. It is worth checking this coupling once every say 250 to 500 engine hrs. There are many benifits to using Aluminium components, but corrosion is one of the few serious negatives. As soon as you spot any white powder around a joint, it needs to be removed and sorted, because the powder only forms once the moistiure has made it right through and thus corrosion has been well andd truely working. 1 Quote Link to post Share on other sites
marinheiro 352 Posted February 17, 2022 Author Share Posted February 17, 2022 On 15/02/2022 at 7:36 AM, wheels said: Wasting ones time trying to flush the engine with fresh water, unless you can hook up a hose and run it for 15 min to half an hr. Even then, it may not flush the salt out. Especially if the Salt has worked it's way up into the gap between two mating surfaces. The thing to do is to remove the end cap. Make sure the seal is doing what it should. If the surfaces have become pitted, then have them filed, or machined(depending on how bad, clean and flat. Re seal it with a smear of selant between the gasket and surfaces. The issue is caused by Salty moisture being absorbed by the gasket. Hence why a simple flush will not be sufficient. The Gasket has created a gap between the two surfaces. Once corrosion begins, which it can due to all sorts of complicated reasons, there is just enough galvanic action to then allow it to continue and increase the damage. It is worth checking this coupling once every say 250 to 500 engine hrs. There are many benifits to using Aluminium components, but corrosion is one of the few serious negatives. As soon as you spot any white powder around a joint, it needs to be removed and sorted, because the powder only forms once the moistiure has made it right through and thus corrosion has been well andd truely working. the idea is not so much to flush salt away (altho as you say a 15-30min run on freshwater will help), rather to ensure salt water is not left in the Heat Exchanger undisturbed for long periods. Yanmars, and I expect other engines as well, use O Rings on the end caps, so the issue is salt getting between the O Ring and the Aluminium shell Quote Link to post Share on other sites
