Dtwo 157 Posted September 6, 2021 Share Posted September 6, 2021 Working through adding a couple of 100W panels. I need to have a contactor in the feed so the lithium BMS can switch off the panels if necessary. I've been recommended the Gigavac P115bda but I am having a real problem sourcing them for reasonable $$. Any suggestions for an alternate? Here is the P115 spec. https://www.gigavac.com/products/p115bda Quote Link to post Share on other sites
Island Time 1,230 Posted September 6, 2021 Share Posted September 6, 2021 Why would you use a mechanical relay? Consumes power with the coil.. What about a solid state (mosfet based) relay - about $20-30 on amazon... Use a normally closed, opens when BMS turns it off. Whats the solar controller? You need to be sure that it can either be switched off, or can deal with a disconnect. Quote Link to post Share on other sites
Dtwo 157 Posted September 6, 2021 Author Share Posted September 6, 2021 6 minutes ago, Island Time said: Why would you use a mechanical relay? Consumes power with the coil.. What about a solid state (mosfet based) relay - about $20-30 on amazon... Use a normally closed, opens when BMS turns it off. Whats the solar controller? You need to be sure that it can either be switched off, or can deal with a disconnect. Do you have an example of the solid state relay? The P115 is normally open and apparently is low power consumption (I wish I knew more about this stuff....). Looking at the Victron Smartsolar MPPT, with the relay between panel and controller. Quote Link to post Share on other sites
Island Time 1,230 Posted September 6, 2021 Share Posted September 6, 2021 Like this https://www.amazon.ca/LANTRO-JS-SSR-40DA-Output-24-380V/dp/B0924R6JD9/ref=sr_1_4?dchild=1&keywords=solid+state+relay+DC+40a&qid=1630919872&sr=8-4 Quote Link to post Share on other sites
Island Time 1,230 Posted September 6, 2021 Share Posted September 6, 2021 But if you go to this series victron SmartSolar MPPT 150/70-Tr they have a built in relay for this... Quote Link to post Share on other sites
Dtwo 157 Posted September 6, 2021 Author Share Posted September 6, 2021 I'm only looking at the 75/10 or 75/15. I'd run a separate controller per panel to deal with shading. Thanks for the link! That is a great help. Quote Link to post Share on other sites
Island Time 1,230 Posted September 6, 2021 Share Posted September 6, 2021 200w panels you want the 15. 1 Quote Link to post Share on other sites
mcp 32 Posted September 6, 2021 Share Posted September 6, 2021 If you are using a Victron Smart Solar MTTP, you do not need a relay or a switch for a BMS. You just need someone to program the Victron properly for you. PM me if you need help. Also what BMS are you using? Most are overly complicated for little reason. @Island Time Solid state relays generate heat when closed as well, because of high internal resistance. A mechanical latching relay would be the most idea relay for this instance, if it can be controlled from the devices. Quote Link to post Share on other sites
Island Time 1,230 Posted September 6, 2021 Share Posted September 6, 2021 2 hours ago, mcp said: If you are using a Victron Smart Solar MTTP, you do not need a relay or a switch for a BMS. You just need someone to program the Victron properly for you. PM me if you need help. Also what BMS are you using? Most are overly complicated for little reason. @Island Time Solid state relays generate heat when closed as well, because of high internal resistance. A mechanical latching relay would be the most idea relay for this instance, if it can be controlled from the devices. Agreed, a latching relay would be ideal, but should not be needed with the Victron controller, which can be set up for Lithium... Quote Link to post Share on other sites
