Buying a bilge pump
28 minutes ago, Black Panther said:
I've got one of those jabsco ones 8n front of the fresh water pressure pump, no problem.
But the shower drain pump just replaced is in a very small sump, no extra room at all. Considering my inability to look at a replacement I chose like for like. If/ when this one dies (about 2 years historically) I'll see if there's a suitable diaphragm pump that fits.
Here's a fun thought, most boats have these as bilge pumps, wonder now how my bilge pumps are doing. I normally flick the switch once a month and they make a noise.  Now I'm wondering if they need a closer look.
The advantage of the diaphragm pumps is that they are (usually) self priming - so only the pickup hose needs to  be in the the bottom of the sump, the pump itself can be remote mounted wherever convenient.
50 minutes ago, Fogg said:
On bilge pumps I’ve just ordered one of these. Triggered by a feeling that the sea gods were sending me a message after 2 weekends in a row I was first vessel in attendance of slowly sinking boats whose average bilge pumps couldn't keep up with ingress. It has motivated me to upsize. I might even get a second one to give me 8,000 GPH. But hope I never need it. A bit like a life raft. But cheaper.
In addition to an installed 4000 pump, I have one of these as a portable with a 3" lay flat hose for discharge
45 minutes ago, Black Panther said:
Having seen the mess in the bilge after being inverted I would suggest nearly every bilge pump I've ever seen would clog in no time flat..
Absolutely right. Hence an easy clean strum box is needed...
On 19/09/2021 at 2:27 PM, marinheiro said:
one of these, Whale Gulper 220
or Jabsco
41Bx8FN6BvL_large.jpg?v=1623597587
or Johnson
any of the wire mesh strainers will do
I've bought the big Johnson L4000 but need a smaller diaphragm pump for the lower sump.
I really like the look of the Whale Gulper 220. Any idea if there's a supplier in NZ?
2nd choice the Johnson SPX - I couldn't see one on the marine deals website that looked like this - any idea of the model?
