Black Panther 1,568 Posted October 19, 2021 Share Posted October 19, 2021 Their own solid vang? I remember seeing a design a while back using squash balls. Quote Link to post Share on other sites
Ex Machina 365 Posted October 19, 2021 Share Posted October 19, 2021 5 minutes ago, Black Panther said: Their own solid vang? I remember seeing a design a while back using squash balls. Yeah I’ve seen that design too very simple and cheap Quote Link to post Share on other sites
Kevin McCready 83 Posted October 20, 2021 Share Posted October 20, 2021 Quote Link to post Share on other sites
Black Panther 1,568 Posted October 20, 2021 Author Share Posted October 20, 2021 Also if I remove the toppi g l7ft what happens to the back of the stackpac Quote Link to post Share on other sites
Vorpal Blade 89 Posted October 20, 2021 Share Posted October 20, 2021 5 hours ago, Black Panther said: Also if I remove the toppi g l7ft what happens to the back of the stackpac You would need the battens in the bag to be far enough aft to replicate the same position for the zip system to work. Quote Link to post Share on other sites
Bradz 18 Posted October 20, 2021 Share Posted October 20, 2021 8 hours ago, Black Panther said: Their own solid vang? I remember seeing a design a while back using squash balls. We used to use squash balls under concrete pavers to support turntables in nightclubs/dance parties etc. We replaced them every month or so. They rapidly lose the air within and quickly become a mush of rubber when under constant pressure. 1 Quote Link to post Share on other sites
Island Time 1,211 Posted October 20, 2021 Share Posted October 20, 2021 8 hours ago, Black Panther said: Their own solid vang? I remember seeing a design a while back using squash balls. Nope, but I've thought about it. Should we build 2?? Quote Link to post Share on other sites
Black Panther 1,568 Posted October 20, 2021 Author Share Posted October 20, 2021 Sounds a plan but i would be 3 as I need two. Need to look at the existing hardware and have a wee think. Quote Link to post Share on other sites
Deep Purple 511 Posted October 20, 2021 Share Posted October 20, 2021 15 hours ago, Black Panther said: Also if I remove the toppi g l7ft what happens to the back of the stackpac You will still need a topping lift. Even the best systems only support the boom temporarily. Without a topping lift your main sheet won't have anything to brace the boom against and it will swing all over the place 1 Quote Link to post Share on other sites
aardvarkash10 943 Posted October 20, 2021 Share Posted October 20, 2021 I'd use urethane skateboard bushings. A lot of early mountainbike suspension systems used urethane bushings as the "spring". Stable, takes huge load, available in a wide range of compression strengths (duro), easily replaced and tuned (stack different duro bushings in different lengths to tune). 1 Quote Link to post Share on other sites
