Pourable foam for a rudder
I need to rebuild my rudder. Who knows where I can buy some suitable closed cell pourable foam? I believe it needs to be about 16lb density, urethane. But thats from Mr Google, so any advice would be appreciated...
30 minutes ago, Black Panther said:
Is more better/ stronger?
Yes, Higher density means harder for the frame to move thru the foam... Jeffa rudders use 90 Kg/m3 foam. The compressive strength of the foam is probably more important, so when the frame presses on the foam it does not give, but seems hardly anyone provides that.. Still researching...
10 hours ago, Island Time said:
Yeah, saw that, but its not really dense enough to be ideal to use in a rudder. Needs to be about 16lb/ft2 or 80kg/m2...
C
Did you call NZ fibreglass and ask? not everything is on their website. I expect if they can't supply it they will at least know who can.
Launched after antifouling in the weekend today. After work tonight, dropped the rudder in the berth and took to the workshop. Tomorrow i'll cut one side out and remove the foam to inspect the frame....
I will use 80kg foam or above. Due to the nature of the internal shape, frames etc, pourable foam (urethane or Epoxy) ensures no voids, it's very difficult to get an exact match with rigid foam. The rudder is off and stripped, the internal frame tangs are broken in several places. Pics to come... 1st job has been to clean up the shaft and frames for repair...
4 minutes ago, slanty said:
As a matter of interest, how did you know this job was due? Loss of steerage? 😉
Nope, normal rudder  bearing play test at antifouling time, revealed movement of shaft in rudder, not heaps, but should be none
Wow, those tangs were already broken?!?  That didn't happen as part of disassembly?
I am most impressed that you can drop your rudder in the berth. Mine would be in the mud along with every bearing.
No Roller bearings in IT, vesconite bearings, just bushes really. These ones I put in in 2002, no sign of wear yet, close on 30,000 Nm since then.
Yes, the tangs (3mm or so stainless) were broken, just sent the shaft to the fabricator to replace the tangs in 6mm, and larger gussets. About $2k for the stainless work.
