Romany 164 Posted December 11, 2021 Share Posted December 11, 2021 I have to replace my start battery. The experts have u believe its gotta be a 'marine' battery. Seems to me to be another way of extracting more wedge Roughly 100% more. As an example - 57MF 530cca 12v car batt =$133 but double that for a 57MF M, also 530CCA. Seems like mmms must be bloody valuable. Isn't 12v 12v no matter what? Quote Link to post Share on other sites
harrytom 698 Posted December 11, 2021 Share Posted December 11, 2021 I never had an issue with a normal car battery.Strapped down properly so it cant move no issue Quote Link to post Share on other sites
Psyche 902 Posted December 11, 2021 Share Posted December 11, 2021 6 hours ago, Romany said: I have to replace my start battery. The experts have u believe its gotta be a 'marine' battery. Seems to me to be another way of extracting more wedge Roughly 100% more. As an example - 57MF 530cca 12v car batt =$133 but double that for a 57MF M, also 530CCA. Seems like mmms must be bloody valuable. Isn't 12v 12v no matter what? If your' not deep cycling it then a car battery should be fine, the load on a starting battery is actually pretty small as long as it has the CCA you need. When you think about it you start the engine, maybe 10-15 seconds max even with glow preheating and maybe run the windlass for a few minutes. Quote Link to post Share on other sites
wheels 544 Posted December 11, 2021 Share Posted December 11, 2021 The marine versions are built with power boats in mind. They have to handle a lot more pounding and thus are internally supported better hence the price difference. For a sailboat, the hammering is not an issue, so an ordinary start battery is just fine. 1 Quote Link to post Share on other sites
aardvarkash10 1,160 Posted December 11, 2021 Share Posted December 11, 2021 agreeing with the above, the only move I would make is to a sealed gel rather than flooded (wet) cell. Batteries tend to be buried in the bowels of a yacht to keep weight low, so anything that reduces maintenance is a good thing. Quote Link to post Share on other sites
wheels 544 Posted December 11, 2021 Share Posted December 11, 2021 I agree with non spill, but AGM is he better choice for start rather than Gel. Gel is not so good at giving up the juice. AGM performs a little more like FLA with faster Amp production in a high draw situation. But if cheap is the key point here, then FLA will always be the cheapest. 1 Quote Link to post Share on other sites
CarpeDiem 570 Posted December 11, 2021 Share Posted December 11, 2021 The minimum I settle for is AGM 700CCA Bolt down terminals So long as whatever battery you choose has enough CCA to turn over the engine once. The rest are pros and cons. There's no right or wrong answer. Quote Link to post Share on other sites
Romany 164 Posted December 12, 2021 Author Share Posted December 12, 2021 Thanks Quote Link to post Share on other sites
whitepointer 34 Posted December 12, 2021 Share Posted December 12, 2021 Just replaced my endurant FLA start battery, it was 11 years old, no brainer, replaced with another endurant, 1 Quote Link to post Share on other sites
