ballystick 83 Posted March 11, 2022 Share Posted March 11, 2022 I am currently having more problems with my Nexus NX2 system depth giving a no response, does anyone know what I should detect voltage wise on the wiring? There are 3 wires to the depth transducer which doesn't look to be on the network. What are the white and brown (can I feed 12V to this one? as there is no supply) wires used for? I am starting to upgrade to B&G but currently waiting for a transducer. Quote Link to post Share on other sites
ballystick 83 Posted March 11, 2022 Author Share Posted March 11, 2022 Had a look at the server for the system and there isn't any LED flashing for the depth so that indicates a fault in the Server itself..... The beginning of the end I suspect. Quote Link to post Share on other sites
180S 20 Posted March 12, 2022 Share Posted March 12, 2022 I too run a nexus system with all bits except the depth sounder, have that wired in to the Lowrance MFD. Not too sure a lack of flashing indicates a server fault, I.e if you remove the log or wind there is no flashing either as there is no pulses coming in. You maybe right as I have no depth garage to confirm if it should flash, certainly the compass doesn’t. Am a big fan of the nexus gear, the wind sensor with a horizontal axis is superior to anything out there today in my book. 1 Quote Link to post Share on other sites
180S 20 Posted March 12, 2022 Share Posted March 12, 2022 Well I tell a lie. Have just checked and the compass does have a flashing lite, and the log while stationary has a steady led, but I know it does flicker whilst underway. 1 Quote Link to post Share on other sites
