Steve 61 Posted March 18, 2022 Share Posted March 18, 2022 Has anyone had experience with the NZ sun affecting carbon spars? Quote Link to post Share on other sites
wheels 544 Posted March 18, 2022 Share Posted March 18, 2022 UV won't affect the Carbon itself, but it sure can affect the Resin. Thus often a clear coat of Polyurathane with a UV stabalizer is coated over top. But even then, the clear coat can break down over time too and it needs to be maintained. Not using a clear coat usually results in the Epoxy yellowing from UV. I would not expect much in the way of reduction in strength of the spar as the Carbon should stop the UV from penetrating any further than the first layer. Quote Link to post Share on other sites
harrytom 698 Posted March 18, 2022 Share Posted March 18, 2022 7 hours ago, wheels said: UV won't affect the Carbon itself, but it sure can affect the Resin. Thus often a clear coat of Polyurathane with a UV stabalizer is coated over top. But even then, the clear coat can break down over time too and it needs to be maintained. Not using a clear coat usually results in the Epoxy yellowing from UV. I would not expect much in the way of reduction in strength of the spar as the Carbon should stop the UV from penetrating any further than the first layer. Clear hates the sun,look at imported cars ,particularly the plastic bits ,seems to peel off nicely. Quote Link to post Share on other sites
Psyche 955 Posted March 18, 2022 Share Posted March 18, 2022 17 hours ago, Steve said: Has anyone had experience with the NZ sun affecting carbon spars? Dinghy or keeler? Quote Link to post Share on other sites
wheels 544 Posted March 18, 2022 Share Posted March 18, 2022 8 hours ago, harrytom said: Clear hates the sun,look at imported cars ,particularly the plastic bits ,seems to peel off nicely. UV stabalizing additives are in themselves, not clear. Plus any material like Plastics and paints etc need two different forms of stabalizers to work in conjuction and offer the best protection. Usually one acts as a reflecter of UV and the other absorbs the energy of the UV Photon. Both work together well as a team, but each on it's own works very poorly. So there is this difficulty in producing a clarity of product vs great UV protection. So mixing stabalizes into a clear coat has always been difficult while trying to maintain the clarity of the coat. By the way, Black does not absorb UV, unlike all other bands of visible light and through into IR, which is absorbed by Black. So the most common UV stabalizing product in Black products is Carbon Black. Quote Link to post Share on other sites
Ex Machina 391 Posted March 19, 2022 Share Posted March 19, 2022 Paint it black with durepox if you want to retain its black look Quote Link to post Share on other sites
MartinRF 82 Posted March 20, 2022 Share Posted March 20, 2022 Having watched this happen to my clear coated decks my conclusion is that the UV filter is not good enough to stop the epoxy below from breaking down. It only slows it down and eventually the bond between epoxy and clear coat gives up. The clear coat flakes off. Wait long enough and the wood below the epoxy laminate is affected enough for that bond to break. This never happens where I have paint on top of the epoxy. Wood-epoxy cat. 35 years in Sweden so less UV than you have. https://www.reflectometrist.eu/ I am re-doing the clear coat on the decks this spring. I am scraping off the old stuff this weekend. Most of it comes off with little effort. Not so where it is in the shade. This is the third time I do this, if memory serves. Two-pot paint also breaks down but is a (much) slower process. /Martin Quote Link to post Share on other sites
