Black Panther 1,585 Posted April 7, 2022 Share Posted April 7, 2022 This came up elsewhere, but as of today my list is only 10 items - first time that's happened. 4 are underway and 6 not started yet. Anyone else? Quote Link to post Share on other sites
Kevin McCready 83 Posted April 8, 2022 Share Posted April 8, 2022 It's no fun unless you say what's on your joblist. On my joblist I only have one job: make a joblist. Quote Link to post Share on other sites
aardvarkash10 959 Posted April 8, 2022 Share Posted April 8, 2022 3-week haul-out in May in no specific order. antifoul repaint topsides repair longitudinal crack line in the inner cabin roof new name ceremony!! stern gland standing and running rig inspection inc replace bulbs/LEDs in the mast lights and possible spinnaker halyard replacement replace the worn out leach reefing jammer on the boom with a better jammer or with a clutch clean bilges (after stern gland replacement) complete fitting the autopilot oil change and filters replace the stripper on the anchor winch and service the winch service the sheet winches. Non-haul-out items in no specific order assess storage to optimise space for food, clothing, equipment etc based on frequency of access, speed of access, condition of the storage space (damp/dry; hot/cold; etc) and the other usual storage criteria assemble grab bag items and put them in the grab bag specifically purchased a year ago (no procrastination to see here folks, move along...) test run the diesel heater to ensure its ok for the winter season. collect parts and inspiration for the construction of the kero/diesel pressure stove to replace LPG stove. Break out the silver brazing rods, repurpose some stainless steel as the main chassis and a fire extinguisher body as the fuel reservoir/pressure tank, play with it a bit to get it burning hot, clean and controllable in approximately that order. work out what is required to get to Cat 4 so we can do some club racing if we choose to revise headsail lead setup - its blown two sheet blocks so far so low friction rings might make life cleaner, consider in-haul b/c the current clew position is well outboard and it would be nice to point a bit higher (according to the Grumbling Classes resident on the tiller) Design and construct a table that can be stored easily in the cabin but set up in the cockpit for those pleasant balmy summer afternoon conviviality sessions Quote Link to post Share on other sites
Black Panther 1,585 Posted April 8, 2022 Author Share Posted April 8, 2022 Design and construct a table that can be stored easily in the cabin but set up in the cockpit for those pleasant balmy summer afternoon conviviality Bunnings, cheap, believe there is now a bamboo version 1 Quote Link to post Share on other sites
Black Panther 1,585 Posted April 8, 2022 Author Share Posted April 8, 2022 My list Replace bow thruster switch Buy some mainsail slides for spares Replace main topping lift and reefing lines Attempt to make my autopilot talk to a kindly donated gyro Finish installing deckwash system New cockpit cushions New main cabin upholstery Attack engine oil leaks (again) Buy some oil Touch up Grey paint at transom No 11 which I finished this morning was adjust the pitch on the new kiwiprop. The job took less time than putting on the wetsuit. Impressed. Quote Link to post Share on other sites
Dave 11 Posted April 8, 2022 Share Posted April 8, 2022 1 hour ago, Black Panther said: My list Replace bow thruster switch Buy some mainsail slides for spares Replace main topping lift and reefing lines Attempt to make my autopilot talk to a kindly donated gyro Finish installing deckwash system New cockpit cushions New main cabin upholstery Attack engine oil leaks (again) Buy some oil Touch up Grey paint at transom No 11 which I finished this morning was adjust the pitch on the new kiwiprop. The job took less time than putting on the wetsuit. Impressed. Slides or slugs BP? I've got these you're welcome to: 12mm diameter by roughly 70mm. Quote Link to post Share on other sites
Black Panther 1,585 Posted April 8, 2022 Author Share Posted April 8, 2022 12 minutes ago, Dave said: Slides or slugs BP? I've got these you're welcome to: 12mm diameter by roughly 70mm. Thanks but I'm after 7/8 slides. Quote Link to post Share on other sites
DrWatson 375 Posted April 13, 2022 Share Posted April 13, 2022 Shall I give the real list or the list for this weekend - being the first long weekend away ever with my wife on her boat, sans kids. Quote Link to post Share on other sites
