Psyche 904 Posted May 9, 2022 Author Share Posted May 9, 2022 Pretty sure that if ultrasound worked to prevent fouling there would be some big players out there, maybe it does but when you turn the dial up enough to cook a chicken? Heres some more on boundary layers and yachting kim-klaka-how-smooth-a-bottom.pdf Quote Link to post Share on other sites
wheels 544 Posted May 9, 2022 Share Posted May 9, 2022 Thats a good article. But I need to correct one error. 5 Boaties sitting around discussing the subject will result in 10 answers, not 6. The overall article highlights the one common point. There is no one simple answer and for every attempt to reduce Hull resistance through the water, there is a whole new set of Physical laws that fight against you. There is one important point that always needs to be kept in mind. Friction and Resistance to movement is as much your friend as is your enemy. If you have no friction/resistance, you will never sail into the wind at all, nor even sail beam on and you will only ever go as fast down wind as the wind itself. So there needs to be some form of resistance so as things like Hull shape, Rudder shape, Keel shape/size and length, all work in combination, so as to create a forward movement when another force is applied (ie wind in sails). With no friction and resistance, water would simply flow around rather than over a surface. Remember that all the shapes of a Hull are such to create lift through the water. Said another way to make it easier to understand, a Car tire will give you greater grip the wider it is. But the friction ends up increasing as well, so it's harder to roll on the road and you use more fuel. If you decide to reduce that friction to save fuel, lets say you spray oil on the surface of the tire as you travel, you end up no longer staying on the road. You cannot turn corners, you cannot maintain a straight line and you cannot accelerate etc. Quote Link to post Share on other sites
MartinRF 79 Posted May 10, 2022 Share Posted May 10, 2022 Kim Klaka used to hang out on rec.boats on Usenet. He is (used to be?) a researcher at an institute or uni in western Australia. Lars Larsson used to be a hydrodynamics professor at the university I got my degrees at (*). My brother was one of his PhD students. My brother met Kim Klaka during a trip down under in 1995. Now this pops up here. Small planet /Martin *) My boat was built in the workshop of the marine engineering department of that university. Usenet: https://en.wikipedia.org/wiki/Usenet 1 Quote Link to post Share on other sites
Psyche 904 Posted May 10, 2022 Author Share Posted May 10, 2022 I found that article years ago and kept it for occasional re reading, most people know its important but just not how much advantage it is to have a smooth clean hull. 3% is free money! Quote Link to post Share on other sites
MartinRF 79 Posted June 7, 2022 Share Posted June 7, 2022 So I ended up doing a complete antifouling 'facelift'. It cost me a month of our sailing season plus, of course, a bunch of money. I went for Hempaspeed TF which is not silicone based so this post is off topic. Hempaspeed TF is a bit odd to apply as it is rather viscous and I found it would not flow to a smooth surface which is a bit of a dissapointment after all the work. It is glossy which is also a little odd for an antifouling in my experience. It will be interesting to see if algae and barnacles like it. /Martin PS It is my understanding that Hempaspeed TF is currently only released in Scandinavia. 1 Quote Link to post Share on other sites
wheels 544 Posted June 7, 2022 Share Posted June 7, 2022 Hempaspeed is a "Hydrogel" type AF. In other words, once in the water the surface becomes slimey/slippery to the touch. The idea came about due to the fact that Fish have a natural Hydrogel over their skin which prohibits Barnicles growing on them. Hempaspeed is designed to perform in a similar way. Please keep the forum informed on how you find the performance of this. As form smoothness, I have not used it myself, so cannot comment. It is designed to be applied by roller or brush, so I suspect that the type of roller might be important. One designed for applying Gloss top coats would likely be required. ie. Short Mohair. Quote Link to post Share on other sites
MartinRF 79 Posted June 7, 2022 Share Posted June 7, 2022 Yes, I intend to keep you posted. Yes, short mohair roller. I was coached on the procedure by a recently retired Hempel employee who my old boat building buddy knows through his job as a marine engineer. Disclaimer: my coach admitted that he had no first-hand experience of applying Hempaspeed TF, I will try to quantify and document the 'smoothness' before launching. /Martin Quote Link to post Share on other sites
Ex Machina 391 Posted June 7, 2022 Share Posted June 7, 2022 3 hours ago, MartinRF said: So I ended up doing a complete antifouling 'facelift'. It cost me a month of our sailing season plus, of course, a bunch of money. I went for Hempaspeed TF which is not silicone based so this post is off topic. Hempaspeed TF is a bit odd to apply as it is rather viscous and I found it would not flow to a smooth surface which is a bit of a dissapointment after all the work. It is glossy which is also a little odd for an antifouling in my experience. It will be interesting to see if algae and barnacles like it. /Martin PS It is my understanding that Hempaspeed TF is currently only released in Scandinavia. Sleek looking boat Martin … very little rocker by the looks . What’s the design and where’s the keel/ centreboard ? Quote Link to post Share on other sites
MartinRF 79 Posted June 8, 2022 Share Posted June 8, 2022 All about the boat here: https://www.reflectometrist.eu/ /Martin 1 Quote Link to post Share on other sites
Ex Machina 391 Posted June 8, 2022 Share Posted June 8, 2022 1 hour ago, MartinRF said: All about the boat here: https://www.reflectometrist.eu/ /Martin Awesome mate ! Quote Link to post Share on other sites
MartinRF 79 Posted June 18, 2022 Share Posted June 18, 2022 Finally hit water today. /Martin 1 Quote Link to post Share on other sites
twistanshout 0 Posted September 27, 2022 Share Posted September 27, 2022 Really considering stripping back and using this Hempaspeed tf product. After 3 months how are you finding the fouling? Quote Link to post Share on other sites
Psyche 904 Posted September 27, 2022 Author Share Posted September 27, 2022 On 19/06/2022 at 9:38 AM, MartinRF said: Finally hit water today. /Martin any updates Martin? Quote Link to post Share on other sites
MartinRF 79 Posted September 28, 2022 Share Posted September 28, 2022 8 hours ago, Psyche said: any updates Martin? My plan was to wait till after the boat was out of the water. In short: Works as advertised by which I mean, yes things grow but they are really easily removed. This includes barnacles. I can't just brush them off but a mild nudge with a finger is all that is needed. I have had to clean the boat more but since the work has been easier the sum of work is roughly the same. The only disappointment is how rough the surface is. I have done some more research and now I know what to use for thinning this paint. I will try that for next season. I doubt you really have to repaint each season as I detect no change in the properties of this paint and as far as I understand nothing is depleted during the season. When fresh the surface is mildly hydrophobic and this property is restored every time I clean the surface. /Martin (still sailing when weather and work permits -- have to go to work now) Quote Link to post Share on other sites
Psyche 904 Posted September 28, 2022 Author Share Posted September 28, 2022 Thanks, we will be very interested to see how you get on, how about recoating and touch ups? Quote Link to post Share on other sites
MartinRF 79 Posted September 28, 2022 Share Posted September 28, 2022 I will know nothing about that until April or May. There will be an update if I observe anything interesting when the boat leaves the water for this season in a few weeks time. /Martin Quote Link to post Share on other sites
MartinRF 79 Posted October 11, 2022 Share Posted October 11, 2022 This Sunday: I cleaned bottoms from some green algae on Saturday using my secondary method. The ease of cleaning has not changed over time. The bottoms are clean save for a two small patches I missed. The paint look 100% intact and the mildly hydrophobic behavior is restored after each cleaning. I would guess it would work for at least another season as is. I will, however apply a fresh layer of paint hoping I will achieve a smoother finish this time. /Martin 1 Quote Link to post Share on other sites
Thibault 0 Posted November 30, 2022 Share Posted November 30, 2022 Hello I have read the discussion with great interest. I plan a new AF in march in NZ (whangarei)for my catamaran used for offshore cruising ( we are still in fiji). We currently have ablative, and on tropical waters it does not prevent alguae growth, so we have to clean the hull ourselves every month , which increases the abrasion the AF, but no other option to keep it clean. I am really interested by silicone or hydrogel based product, especially for our use: we live onboard, so it is not a big deal to wash it ourselves regularly by diving, and our boat is fast enough to have above 10knots speed on crossings. Big question is what can we find NZ ? Hempaspeed, though looking to be the perfect match, seems still not available and I Did notsucceed knowing when it will be. Any advice on potential alternatives ? Thanks Thibault Quote Link to post Share on other sites
Ralph East 0 Posted January 30, 2023 Share Posted January 30, 2023 On 28/09/2022 at 8:07 AM, MartinRF said: I have done some more research and now I know what to use for thinning this paint. What thinner is this Martin? I have bought (in Norway)Hempaspeed for my 44 feet steel boat and will apply it in spring. If you want to share your application in further details, Martin, I would very much appreciate. Rolf Quote Link to post Share on other sites
Go-Be 0 Posted April 10, 2023 Share Posted April 10, 2023 On 1/12/2022 at 12:30 PM, Thibault said: Big question is what can we find NZ ? Hempaspeed, though looking to be the perfect match, seems still not available and I Did notsucceed knowing when it will be. Any advice on potential alternatives ? Thibault, what did you find in the end? We are in the same situation: Liveaboard cruisers looking for recommendations on where to get silicone based AF done in NZ. Quote Link to post Share on other sites
