CarpeDiem 575 Posted May 15, 2022 Share Posted May 15, 2022 I am going to replace some winches and the bolt patterns are not compatible. The deck is plywood. What's the best way to fill the old holes so that they're best possible for future possibilities... I used sone knead it aqua on some old cable holes I had, this seemed to work OK. It's cheap and I probably have plenty left. But wondering if there's a better way. Thanks Quote Link to post Share on other sites
wild violet 38 Posted May 15, 2022 Share Posted May 15, 2022 Just epoxy glue some dowels into the old holes fair up and paint 1 2 Quote Link to post Share on other sites
wheels 544 Posted May 15, 2022 Share Posted May 15, 2022 Wild Violet has the proper solution. Wooden Dowel and glue. Next is to use epoxy filler. Kneadit does not have much in the way of "wetting" ability. Epoxy with a little more "excess" of liquid will soak into the timber fibres better. Quote Link to post Share on other sites
Psyche 955 Posted May 15, 2022 Share Posted May 15, 2022 How big are the holes 10mm? I'd just bog them Quote Link to post Share on other sites
whitepointer 34 Posted May 16, 2022 Share Posted May 16, 2022 Tape underneath hole, then run some epoxy into holes, when nearly cured finish off with epoxy filler and primer Quote Link to post Share on other sites
Black Panther 1,833 Posted May 16, 2022 Share Posted May 16, 2022 2 minutes ago, whitepointer said: Tape underneath hole, then run some epoxy into holes, when nearly cured finish off with epoxy filler and primer That's what I did, no problems. Quote Link to post Share on other sites
wkavinsky 1 Posted May 16, 2022 Share Posted May 16, 2022 Definitely fill with epoxy (with filler or without is fine). It'll be stronger, and more water proof than the original wood. 1 Quote Link to post Share on other sites
jay 3 Posted May 21, 2022 Share Posted May 21, 2022 You might be able to line up one or more of the old holes with the new hole pattern, reducing the number of new holes needed. If you drill the new holes oversize 1st, then you can epoxy fill the old and new holes at the same time as described above, wait until cured, then re-drill the new holes to correct size taking care to only drill the epoxy fill. This way the new holes are epoxy sealed to stop water getting into the ply. Fairing might not be necessary if the holes are all covered by the new winch. 2 Quote Link to post Share on other sites
