Island Time 1,211 Posted July 3, 2022 Share Posted July 3, 2022 This will revolutionize cruising! https://gizmodo.com/elon-musk-starlink-wifi-cars-boats-planes-1849133879?utm_campaign=Gizmodo&utm_content=&utm_medium=SocialMarketing&utm_source=facebook Quote Link to post Share on other sites
Black Panther 1,568 Posted July 3, 2022 Share Posted July 3, 2022 For better or worse? 2 Quote Link to post Share on other sites
Island Time 1,211 Posted July 4, 2022 Author Share Posted July 4, 2022 Good question! But you'll be able to have a NZ phone number (via IP phone) from anywhere, and broadband level internet Quote Link to post Share on other sites
Jon 355 Posted July 4, 2022 Share Posted July 4, 2022 Working from mid pacific just became a reality for many I’d say Quote Link to post Share on other sites
aardvarkash10 943 Posted July 4, 2022 Share Posted July 4, 2022 39 minutes ago, Jon said: Working from mid pacific just became a reality for many I’d say so, worse then. Quote Link to post Share on other sites
Island Time 1,211 Posted July 4, 2022 Author Share Posted July 4, 2022 Still a fair way off, here is the current coverage map; The light blue places are covered, and only about 15nm offshore so far. But it's coming... Quote Link to post Share on other sites
CarpeDiem 419 Posted July 4, 2022 Share Posted July 4, 2022 That's a land coverage map, the real coverage is further out to sea. But you are right that the service is still a long long way off being able to provide open ocean coverage in the pacific. They need to launch another ~40,000 satellites for that goal to be achieved. They currently have approval for 12,000 satellites, of which they have launched ~2500. The focus is currently on populated areas. But one day worldwide coverage will exist... There also are no ground stations that we can use yet which will track fast enough to take into account boat movement. It will work on an RV, cause of course they park in one place. The issue at the moment is base stations, so although you can see a satellite from anywhere on earth, eg in the middle of the Indian ocean, that satellite that you can see cannot see a base station. To solve this they need a full mesh - that means the Satellite you can see, sends your transmissions using laser's to another satellite, which can then bounce it to another, and so on until it reaches a satellite that can see a base station. For that full mesh they need more Satellites, lots more satelites. So quite a bit has to happen before we can use it on a boat at anchor. I am not sure what approvals they would need to operate in international waters, currently every country has to provide permission individually to use the spectrum - nfi how that works in international waters... Not withstanding the lack of a marine ground station, anywhere around NZs coast you can use it now. Pretty much at the 200NM limit give or take, east cape. There's a good interactive coverage map here... every dot is a satellite, much SPACE JUNK! Definitely check the map out. Here's a snapshot of NZs coverage area, covered by the honey comb's. The Red dots are the six ground stations in NZ. , 1 Quote Link to post Share on other sites
darkside 61 Posted July 4, 2022 Share Posted July 4, 2022 Plenty of people using it on boats at anchor. Plenty of people using it on boats underway. It is geo fenced in parts of the States but not here it seems. Mine is installed and up an running. The FB group Starlink on Boats is a good source of info. Quote Link to post Share on other sites
Island Time 1,211 Posted July 4, 2022 Author Share Posted July 4, 2022 1 hour ago, darkside said: Plenty of people using it on boats at anchor. Plenty of people using it on boats underway. It is geo fenced in parts of the States but not here it seems. Mine is installed and up an running. The FB group Starlink on Boats is a good source of info. While this is true, the current antenna's are not designed for mobile (boat) platforms. The RV one is ok when stopped. New ones are coming that are designed for movement... Quote Link to post Share on other sites
CarpeDiem 419 Posted July 4, 2022 Share Posted July 4, 2022 1 hour ago, darkside said: Plenty of people using it on boats at anchor. Plenty of people using it on boats underway. It is geo fenced in parts of the States but not here it seems. Mine is installed and up an running. The FB group Starlink on Boats is a good source of info. Nice. Do you have a Starlink supplied base station? Or is it a after market one? I heard the Starlink ones had plastic gears and could not keep up? I don't know if NZ is or isn't Geo-Fenced. They could easily do it here if they wanted to. Quote Link to post Share on other sites
Island Time 1,211 Posted July 4, 2022 Author Share Posted July 4, 2022 1 minute ago, CarpeDiem said: Nice. Do you have a Starlink supplied base station? Or is it a after market one? I heard the Starlink ones had plastic gears and could not keep up? That's my understanding as well, and some have disabled the motors. No personal experience - yet. Quote Link to post Share on other sites
darkside 61 Posted July 4, 2022 Share Posted July 4, 2022 Yes I am aware. But internet is available today, on boats at faster speeds than the fibre coming into our house, unlimited, for $250 a month. We have Starlink RV. There are a lot of videos on YouTube showing how to disable the motors for more stable reception underway and at anchor. Not sure that the gears failing is a problem at all. Apparently if you leave it for a while the dishy just gives up hunting and goes back to flat Quote Link to post Share on other sites
CarpeDiem 419 Posted July 4, 2022 Share Posted July 4, 2022 You may need to log a support call on your fibre, or change ISP. There is no way Starlink will beat NZ fiber for speed. Maybe xDSL but not fibre. Good to read the success stories. Quote Link to post Share on other sites
CarpeDiem 419 Posted July 4, 2022 Share Posted July 4, 2022 Wow, nice speeds on Starlink. That's some of the best in the world. Good to see that happening! I assume you aren't subscribed to a 100mbit/s fibre service? Assuming you aren't buying a slow service, I would definitely log a ticket with your ISP. I just got 870mbit/s to fast.com. Quote Link to post Share on other sites
bigal.nz 59 Posted July 4, 2022 Share Posted July 4, 2022 Anyone want to sell there Iridium go yet? Looking to go offshore next year but Starlink will still be too far away Quote Link to post Share on other sites
darkside 61 Posted July 4, 2022 Share Posted July 4, 2022 Anyhoo it's real and it's here. There will be lots of them very soon. From opening the box to getting internet is about 5 minutes. Is it a good thing? I'm a bit with BP here, go sailing and switch off. But for now it will mean I can spend more days on the boat so I'll take that. We are planning an around NZ this summer so that will be a good test. 1 2 Quote Link to post Share on other sites
khayyam 68 Posted July 4, 2022 Share Posted July 4, 2022 How are zoom calls with that latency? I guess 100ms maybe isn't too bad. Quote Link to post Share on other sites
twisty 164 Posted July 5, 2022 Share Posted July 5, 2022 I guess lying on deck on a warm summer's night contemplating the vastness of space is about to become a thing of the past ! Quote Link to post Share on other sites
