Jasetheace02 9 Posted July 12, 2022 Share Posted July 12, 2022 Would anyone have some advice on a repair for my rudder blade? Would prefer to just repair the few areas of damage and not have to do the whole blade? Cheers. Quote Link to post Share on other sites
aardvarkash10 959 Posted July 12, 2022 Share Posted July 12, 2022 sand the entire blade for repainting. sand a 50mm perimeter around each area of damage to remove the paint and feather it in. fill if required then glass over the sanded area, feather it in. touch up with sealant on the bare areas, then two coats of your approved undercoat and a top coat or two. 1 Quote Link to post Share on other sites
alibaba 76 Posted July 12, 2022 Share Posted July 12, 2022 I'd give the damaged area in pic 1 as much time to dry out as possible. Surface tension and plywood suck water in for quite a distance through the wood microtubes. Then diluted epoxy to soak in and then as for aardvarkash. 1 Quote Link to post Share on other sites
