Macca 0 Posted July 15, 2022 Share Posted July 15, 2022 Hi, I have water leaks (outside to internal) on both port & starboard side's, around mid ships, just under windows (not leaking windows), which have no obvious origin holes from the decks or through fixings. I suspect it is coming from the hull to deck join, which is under the aluminum toe rail. I'm contemplating removing the toe rails to investigate, clean and reseal, if this is found to be the issue. Sending this message if any Ross 830 owners have had same issue...or others if another fix/alternative is known? Cheers Paul Quote Link to post Share on other sites
