Victron Argofet battery isolator 200A- two battery bank
New in box- change of plan. $150
Victron Energy FET Battery Isolator Argo 2002 with alternator energiser terminal. Two batteries, 200A
Similarly to diode battery isolators, FET isolators allow simultaneous charging of two or more batteries banks from one alternator (or a single output battery charger), without connecting the batteries together. Discharging the accessory battery for example will not result in also discharging the starter battery.
In contrast with diode battery isolators, FET isolators have virtually no voltage loss. Voltage drop is less than 0,02 Volt at low current and averages 0,1 Volt at higher currents.
   021718373
