Psyche 630 Posted November 28, 2022 Share Posted November 28, 2022 I tried mast climbing with prussics, you need boots 1 Quote Link to post Share on other sites
CarpeDiem 430 Posted November 28, 2022 Share Posted November 28, 2022 27 minutes ago, Psyche said: I tried mast climbing with prussics, you need boots You can use seat belt type webbing for the foot straps. Then use normal shoes. Or use a foot ladder. https://www.amazon.com/Climbing-Ascender-Ladder-Etrier-Mountaineering/dp/B07XBQBL5B Quote Link to post Share on other sites
CarpeDiem 430 Posted November 28, 2022 Share Posted November 28, 2022 30 minutes ago, aardvarkash10 said: this has been very useful - thanks everyone for the input. The ascending is not bad - I need a second foot loop instead of just one, but other than that it seems good. I will probably get a dedicated descender. I've used the old figure 8 style before, but will likely go with the knucklebone looking type for the reasons given in the video that Psyche posted. I'm not brave enough to think I can do it on a prussic alone. I would suggest investigating a GriGri as an option. And you can also use a GriGri as an ascender with leg prussics or an ascender. Then you're all ready to descend, no change over required, just pull the lever and down you come. The knuckle thing, is known as an ATC. https://www.alpinesavvy.com/blog/using-a-gri-gri-to-ascend-fixed-ropes 1 Quote Link to post Share on other sites
aardvarkash10 959 Posted December 4, 2022 Author Share Posted December 4, 2022 Revised setup in a bit more detail. The upper hand ascender and the chest ascender are both Xinda 22kn devices as are the blue carabiners. I've been practising on an 8mm double braid line, its the smallest diameter the devices are designed for. In use, it will be a 10mm (or maybe 12mm) line. The bosun's chair clips to the bottom of the chest ascender. A strop (yellow and black trace 6mm double braid) runs from the same carabiner to the top of the hand ascender. This means either or both ascenders can be used to hold the bosun's chair. This is required for the changeover to a descender once I'm at the top. The foot loops clip to a short strop that runs up to a carabiner at the bottom of the hand ascender and doubles back to the top of the chest ascender. Push on the foot loop, and the chest ascender is pulled up, with the advantage of a 2:1 purchase. Safety is provided by a prussic that will run on a second halyard, and clips to the safety harness I have. This means there are three locking devices - the two ascenders and the prussic. Once I'm ready to come back to the deck, I unload the chest ascender and remove it from the line. At this point I am still held by the hand ascender. With the chest ascender off, I can fit the descender (I chickened out and went with a figure 8 device). I can lock the descender momentarily to remove the hand ascender from the line, and then I can rappel down. The ascenders stay attached to the chair just in case I cock it up and need to go back up... Quote Link to post Share on other sites
Black Panther 1,584 Posted April 22, 2023 Share Posted April 22, 2023 1 Quote Link to post Share on other sites
Huey 7 Posted April 28, 2023 Share Posted April 28, 2023 https://atninc.com/atn-mastclimber-sailing-equipment.shtml Quote Link to post Share on other sites
Ladyhawk 37 Posted April 29, 2023 Share Posted April 29, 2023 On 28/11/2022 at 3:11 PM, Island Time said: After reading this, and re-looking at the pic, the french prussic pic I posted isnot right either! This IS the one I use, and not had issues with, Very similar, but a little different! Always thought that was a French prussic! Learn something new every day I guess! You do need to get all the weight off it for descending, but that's pretty easy with foot loops. I use four. One shorter one at chest level on the harness/bosuns chair, two foot loops, and another to the safety halyard from the harness/bosuns chair. easy to stop for a rest then! As an aside, this is what I use to attach our bridle to the anchor chain, tie this with a 8mm dyneema loop, then a big soft shackle trough it and the bridle eyes. Holds to the chain like sh*t to a blanket Quote Link to post Share on other sites
