Island Time 1,351 Posted April 24, 2023 Share Posted April 24, 2023 So it does not do this under sail? Check engine mounts, alignment, cutless bearing and strut. 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted April 24, 2023 Share Posted April 24, 2023 57 minutes ago, Island Time said: So it does not do this under sail? Check engine mounts, alignment, cutless bearing and strut. all things the survey should cover. Unless the cause is obvious and obviously reasonable to repair, I'd walk away. Quote Link to post Share on other sites
Clint 1 Posted April 24, 2023 Author Share Posted April 24, 2023 1 hour ago, Island Time said: So it does not do this under sail? Check engine mounts, alignment, cutless bearing and strut. No under sail is fine. Only when motor is moving forward. Quote Link to post Share on other sites
Clint 1 Posted April 24, 2023 Author Share Posted April 24, 2023 13 minutes ago, aardvarkash10 said: all things the survey should cover. Unless the cause is obvious and obviously reasonable to repair, I'd walk away. Being surveyed Thursday, so hopefully it’s an easy fix Quote Link to post Share on other sites
harrytom 698 Posted April 24, 2023 Share Posted April 24, 2023 what happens in reverse? Quote Link to post Share on other sites
Clint 1 Posted April 24, 2023 Author Share Posted April 24, 2023 1 hour ago, harrytom said: what happens in reverse? Haven’t tried reverse yet Quote Link to post Share on other sites
Luigi Vercotti 7 Posted April 29, 2023 Share Posted April 29, 2023 On 23/04/2023 at 7:54 PM, Clint said: Being surveyed Thursday, so hopefully it’s an easy fix Any update on the cause? Quote Link to post Share on other sites
Clint 1 Posted April 29, 2023 Author Share Posted April 29, 2023 4 minutes ago, Luigi Vercotti said: Any update on the cause? Yes had it surveyed an it’s the prop 2 blade folding not geared. looking at a flexifold 3 blade Quote Link to post Share on other sites
Luigi Vercotti 7 Posted April 29, 2023 Share Posted April 29, 2023 4 minutes ago, Clint said: Yes had it surveyed an it’s the prop 2 blade folding not geared. looking at a flexifold 3 blade Thanks for the update. Quote Link to post Share on other sites
Sail Rock 34 Posted May 1, 2023 Share Posted May 1, 2023 On 23/04/2023 at 3:14 PM, Clint said: Would anyone know why this Yacht pulls to the left only under motor? Prop walk (it’s normal) 1 Quote Link to post Share on other sites
