Enlightenment 9 Posted May 1 Share Posted May 1 I need to buy an outboard for my new OLD Pelin Caribou 20 trailersailer which has an adjustable outboard mounting bracket. The last owner had a 9.9hp Johnson but it was left in his garage and got flooded a few months back in the bad weather. I would ideally prefer to get a short shaft 15hp so I could swap it between the yacht and my 3.3m inflatable. As I am living in a motorhome I don't want to carry 2 outboards around everywhere. Can the 20 trailer boat function with a short shaft and will the 40 kg motor greatly impact the sailing performance? opinions and advice would be greatly appreciated! THANKS [Photo] Quote Link to post Share on other sites
aardvarkash10 846 Posted May 1 Share Posted May 1 40kg on the stern may affect performance, but if you stow it centrally, not a lot. Can't comment on the suitability of a particular short shaft motor on your particular transom, but bear in mind that in a howling onshore gale and rising sea, having the prop riding in AND out of the water is not a splendid situation to find yourself in. Quote Link to post Share on other sites
Addem 71 Posted May 1 Share Posted May 1 My experience with transom mounted outboard is that you will need a Long shaft. Anything else will mean you will be a Fairweather sailor only. The effect of the rise and fall of a boat in a choppy sea on a transom mounted ob means it is a challenge to get a long shaft to bite and a short shaft will be hopeless. You might think it will be OK but the number of times I was caught up Harbour with wind against tide trying to get back to the ramp leaves me in no doubt. 40kgs on the transom is huge for a 20ft boat and will kill performance. You'd really struggle to lift it off the bracket while underway so it'll stay there. 3 Quote Link to post Share on other sites
harrytom 574 Posted May 2 Share Posted May 2 8hp 2 cylinder suzuki 2 stroke long shaft is what I had on a davidson m20 1 Quote Link to post Share on other sites
eruptn 77 Posted May 2 Share Posted May 2 The national guidelines is 0.25 hp per foot, so minimum is around 6hp with a bit of safety margin. As mentioned above only long shaft work well on the back of a TY. Props can make a big difference… look for a displacement or sail drive one Quote Link to post Share on other sites
Addem 71 Posted May 2 Share Posted May 2 20 minutes ago, eruptn said: The national guidelines is 0.25 hp per foot, so minimum is around 6hp with a bit of safety margin. As mentioned above only long shaft work well on the back of a TY. Props can make a big difference… look for a displacement or sail drive one Prop makes a huge difference. I changed my yummy to a high thrust and it like a turbo charger. 1 Quote Link to post Share on other sites
Frank 111 Posted May 2 Share Posted May 2 20 hours ago, Enlightenment said: I need to buy an outboard for my new OLD Pelin Caribou 20 trailersailer which has an adjustable outboard mounting bracket. The last owner had a 9.9hp Johnson but it was left in his garage and got flooded a few months back in the bad weather. I would ideally prefer to get a short shaft 15hp so I could swap it between the yacht and my 3.3m inflatable. As I am living in a motorhome I don't want to carry 2 outboards around everywhere. Can the 20 trailer boat function with a short shaft and will the 40 kg motor greatly impact the sailing performance? opinions and advice would be greatly appreciated! THANKS [Photo] 6- 8 hp would be plenty for both boats, your going to get sick of lugging a 15 hp OB real quick 3 Quote Link to post Share on other sites
