Zozza 293 Posted May 15, 2023 Share Posted May 15, 2023 From what I can ascertain via goggle, Meranti 20% heavier and less bendy, and Okoume Joubert lighter, more expensive....but always good to get a Kiwi take on it... So I am thinking Meranti for bulkheads and structural floors, Okoume for settee berths, cabinetry / lockers... Is my thinking sound? Quote Link to post Share on other sites
aardvarkash10 959 Posted May 15, 2023 Share Posted May 15, 2023 I'm picking that the total amount of material is not enough to make either weight or price material overall. I'd use just one so you can match the tone throughout. If you are painting, just choose the best grade (no voids, no fill). 1 Quote Link to post Share on other sites
Zozza 293 Posted May 15, 2023 Author Share Posted May 15, 2023 9 hours ago, aardvarkash10 said: I'm picking that the total amount of material is not enough to make either weight or price material overall. I'd use just one so you can match the tone throughout. If you are painting, just choose the best grade (no voids, no fill). Thanks Aard, Mix of painting and varnish...though that is another question...clearcoat or varnish for an interior? any opinions? Or it don't matter - whatever you feel looks best? All this is new to me - if I ask "WTF"? technical questions over time, be aware I am coming from a background of sitting at my desk on me ar$e 9-5, never done a trade and little DiIY...but I can no longer afford to pay people to do up the boats I buy, so I got me a deep learning curve. 1 Quote Link to post Share on other sites
Clipper 343 Posted May 15, 2023 Share Posted May 15, 2023 I have used meranti and okoume on dinghy builds. I understand the meranti is stronger, but the stuff I used had quite a rough grain/less smooth face than the okoume. It is quite a bit heavier too. but of course, cheaper! Im a bit of a weight nazi on boats, so Id use Okoume, for weight, and nicer finish I have the opposite problem of you, my boat has NO wood and and I want to keep it that way. so foam, glass, carbon, and white paint for me... 2 Quote Link to post Share on other sites
Zozza 293 Posted May 15, 2023 Author Share Posted May 15, 2023 34 minutes ago, Clipper said: I have used meranti and okoume on dinghy builds. I understand the meranti is stronger, but the stuff I used had quite a rough grain/less smooth face than the okoume. It is quite a bit heavier too. but of course, cheaper! Im a bit of a weight nazi on boats, so Id use Okoume, for weight, and nicer finish I have the opposite problem of you, my boat has NO wood and and I want to keep it that way. so foam, glass, carbon, and white paint for me... Heh, yeah…I contemplated similar, but as I intend to eventually liveaboard some wood eye candy down below sort of soothing to the eye.., but on deck I will not be bothered to varnish anything methinks… Quote Link to post Share on other sites
Black Panther 1,586 Posted May 15, 2023 Share Posted May 15, 2023 Did some say varnished plywood interior? 2 Quote Link to post Share on other sites
LE Bb 25 Posted May 15, 2023 Share Posted May 15, 2023 Our 3 go to's are okoume, yellow cedar, and iroko. When you say structural floors can you give and example, not a place for ply in my mind. Quote Link to post Share on other sites
waikiore 399 Posted May 15, 2023 Share Posted May 15, 2023 Okoume (Gaboon) is quite a bit lighter and will soak up far less resin than Meranti when you are sealing it, though be careful there are varying qualities on the market here -some are all muck core with thin veneers -though if its Joubert brand should be alright. I would underline LE 's comments above and agree entirely. 1 Quote Link to post Share on other sites
Psyche 632 Posted May 16, 2023 Share Posted May 16, 2023 look for even plys and plenty of them, Joubert Gaboon is reliable and dont worry about price as its not a giant Spencer! Dont be afraid to go though the pile and pick out the pretty faces. Just make sure you coat the end grain with a couple of good coats of epoxy, in the interior varnish on the faces is fine, no need to epoxy the lot unless you really want to. the only there caveat is any potential water traps absolutely need to be epoxied. Some people roll a few coats of epoxy on the whole sheet before cutting, uses a bit more but much easier to finish on the flat and less tearout 1 Quote Link to post Share on other sites
Farina 2 Posted May 16, 2023 Share Posted May 16, 2023 Sapele is also a good option. Quote Link to post Share on other sites
Zozza 293 Posted May 16, 2023 Author Share Posted May 16, 2023 4 hours ago, LE Bb said: Our 3 go to's are okoume, yellow cedar, and iroko. When you say structural floors can you give and example, not a place for ply in my mind. What I mean is bulkheads in the bilge to support the keel because i have removed the integral water tank.., my understanding is the correct boatbuilding terminology for these is “floors”? Below is s photo showing how looks now with integral water tanks removed. Quote Link to post Share on other sites
waikiore 399 Posted May 16, 2023 Share Posted May 16, 2023 Yes the strong athwartship members (usually laminated ) are keel floors supporting the hull and keel attachment. Whats the design? Quote Link to post Share on other sites
Zozza 293 Posted May 16, 2023 Author Share Posted May 16, 2023 1 hour ago, waikiore said: Yes the strong athwartship members (usually laminated ) are keel floors supporting the hull and keel attachment. Whats the design? It’s a ‘Twister’ Kim Holman (UK) design https://sailboatdata.com/sailboat/twister-28/ Quote Link to post Share on other sites
Zozza 293 Posted May 16, 2023 Author Share Posted May 16, 2023 8 hours ago, Black Panther said: Did some say varnished plywood interior? You could host a Town Hall Meeting inside of their....a Gore one at least Quote Link to post Share on other sites
LE Bb 25 Posted May 16, 2023 Share Posted May 16, 2023 Wasn't much holding them in. Whats your intentions with the yacht? eg coastal or offshore What were the original floors made from ? hard to tell scale but looked about 40mm thick Quote Link to post Share on other sites
Zozza 293 Posted May 16, 2023 Author Share Posted May 16, 2023 9 minutes ago, LE Bb said: Wasn't much holding them in. Whats your intentions with the yacht? eg coastal or offshore What were the original floors made from ? hard to tell scale but looked about 40mm thick Hi Le , offshore No floors - purely the integral tank only in that area Quote Link to post Share on other sites
Black Panther 1,586 Posted May 16, 2023 Share Posted May 16, 2023 1 hour ago, Zozza said: You could host a Town Hall Meeting inside of their....a Gore one at least Angela has cooked a Thanksgiving turkey and fed 16 people at that table. 1 Quote Link to post Share on other sites
vb1 0 Posted May 16, 2023 Share Posted May 16, 2023 1 hour ago, Black Panther said: Angela has cooked a Thanksgiving turkey and fed 16 people at that table. Hah, 16 - amateur! Total stocktake was 32. Floating a bit low though. And also on topic too, back beam is 600 x 120mm gaboon ply box beam and a bit of carbon. Quote Link to post Share on other sites
Black Panther 1,586 Posted May 16, 2023 Share Posted May 16, 2023 44 minutes ago, vb1 said: Hah, 16 - amateur! Total stocktake was 32. Floating a bit low though. And also on topic too, back beam is 600 x 120mm gaboon ply box beam and a bit of carbon. I think I'm in that picture. But I'll still claim the win as we all sat at the table. Quote Link to post Share on other sites
waikiore 399 Posted May 16, 2023 Share Posted May 16, 2023 Is she one of the Keith Atkinson built Holman boats? Quote Link to post Share on other sites
