Guest 141 Posted February 17, 2025 Share Posted February 17, 2025 I need to spray/brush something hard onto areas of high wear like turn of hull and deck and open transom that gets hammering. I can terminate on transition so I dont have to blend out. I have to get hauled next couple of weeks so wonder if I prep and spray with Durapox white with clear over or go whole hog and spray gelcoat from NZ fibreglass (maybe with duratec additive to make it flow out a bit) and then wet sand it back? I guess gelcoat would be longest lasting solution? Done a few miles of wetsanding polishing over watercraft in past, so under no delusion. But a bit rusty. Topsides are International 2p (interspray 900 from memory) deck is gelcoat, with 50mm radius to TS. Quote Link to post Share on other sites
Psyche 973 Posted February 17, 2025 Share Posted February 17, 2025 Gelcoat is tough, it's not paint and its a one and done application. Durepox is very tough but its still paint, will not last like gelcoat but will be easier to apply. I brushed on gelcoat for a similar job, very happy with the result. 1 Quote Link to post Share on other sites
LE Bb 41 Posted February 17, 2025 Share Posted February 17, 2025 Durepox with accelerator goes pretty hard and durable, gelcoat or flowcoats are a pain in the arse. you could also try duratec from ATL 1 Quote Link to post Share on other sites
Frank 236 Posted February 17, 2025 Share Posted February 17, 2025 Normally I wouldnt use an Epoxy paint that has direct exposure to UV but this Durapox looks to be different, its some sort of Urethane/epoxy hybrid, I havent heard of it before, might try it sometime. Quote Link to post Share on other sites
Guest 141 Posted February 17, 2025 Author Share Posted February 17, 2025 Apparently most of the UV inhibitor is in the clear. Its a primer and top coat all in one, but comes out satin, so if you want a gloss, clear over; or mix in 25% and do all at once. Also takes acrylic lacquer over readily. I remember doing multistages of prep, 410 fairing compound, hi build interlux surfacer and lastly tie coat but the Altex 2P topcoat. (15yrs ago) It didnt stick very well as it turns out. I ran out of interspray 900 and they didn't sell 1L. 4L was like $400. What ever I do has to be thick and be adhesion tested. I'd wager the durapox will adhere better than polyester gelcoat. Hopefully I will just have to sand off tiecoat. (15yrs yro) Perhaps i should do a couple of coats of interprotect for adhesion guarantee. Anybody know if gelcoat sticks to interprotect? Quote Link to post Share on other sites
LE Bb 41 Posted February 17, 2025 Share Posted February 17, 2025 Durepox is the best adheiring paints we have ever used, kind of a one hit wonder. The only down fall is antifouling doesn't like sticking to it, but primercon fixes that. Yes it's a urethane, so it doesn't yellow like epoxy primers. Quote Link to post Share on other sites
Guest 141 Posted February 18, 2025 Author Share Posted February 18, 2025 And you can patch and polish? Quote Link to post Share on other sites
harrytom 698 Posted February 18, 2025 Share Posted February 18, 2025 On 17/02/2025 at 3:51 PM, Guest said: go whole hog and spray gelcoat from NZ fibreglass Depending on size of area may stick out like the perverbal dog b#$.s Remember gel goes on first in a mould then glassed up. I did a small patch and colour matching was a pain theres white and theres white. in the end resin n paint. Next time will look at durepox,apparently adheres well. Quote Link to post Share on other sites
