k88 9 Posted July 24, 2025 Share Posted July 24, 2025 As my motor and sail drive is newly installed, I wonder if it would be a good idea to put a strainer/filter between the raw water pump outlet and the inlet to the heat exchanger to prevent bits of rubber from entering the heat exchanger, should the impeller break down (as they do) as a precaution? Quote Link to post Share on other sites
Island Time 1,358 Posted July 24, 2025 Share Posted July 24, 2025 Usually they get caught in the front of the heat exchanger - just take off the front end and look if needed... Quote Link to post Share on other sites
CarpeDiem 587 Posted July 24, 2025 Share Posted July 24, 2025 And if they don't get caught in the heat exchanger they've gone overboard with the exhaust. Quote Link to post Share on other sites
waikiore 523 Posted July 24, 2025 Share Posted July 24, 2025 Strainer between inlet and raw water pump and change the impeller every year or so seems to work. Quote Link to post Share on other sites
