Frank 232 Posted January 4 Share Posted January 4 Hi all, hoping to tap into the collective wisdom of the audience. So my D1-20 saildrive was at idle and in neutral when there was a "Clonk" sound and it stopped and would not re-start. This unit only has 350 hrs on it but it is not under warranty (long story won't bore you with detail) Checks done Eng Oil level Normal Eng temp at the time was normal (90 degC) Coolant level normal Raw water intake/strainers clear and water flowing Jabsco impeller check and found satisfactory (had been recently changed) No over-temp alarms No low oil pressure alarms No rope fouled propellor Propellor turns freely with gearbox in neutral Engine cannot be turned in either direction with a 1/2 inch power bar and socket on the crankshaft V belt pulley. All scheduled maintenance up to date. Questions re next steps , should I Pull an injector and check for hydro lock ? Take Rocker Cover off and check for a bent valve stem ? Split gearbox from engine and see if the engine turns freely on its own (implying its a gearbox issue) Pull the starter motor off and check pinion/bendix gear etc I have already contacted volvo at Beaumont street with the same questions in advance of a potential workshop visit Has anyone else experienced something similar and if so what was the cause. Quote Link to post Share on other sites
John B 119 Posted January 4 Share Posted January 4 Geez, I feel for you. It's hard to imagine a hydro lock from idling ,and for it to lock enough to prevent turning both ways it's more than one cylinder. And it's not a rope on the prop. So it sounds mechanical to me, but by your own diagnosis you're well onto it and would see anything obvious like a thrown/ jammed up belt. Maybe drop off the belt anyway and check the water pump and the alternator moves. Best of luck Quote Link to post Share on other sites
aardvarkash10 1,176 Posted January 4 Share Posted January 4 The clonk sound is depressing.... If the crank won't turn in either direction that sounds catastrophic. Even a dropped valve shouldn't stop the crank from turning. I'm not sure how easy it is to uncouple the gearbox from the engine. If it's relatively simple, that would identify if the clonk was engine or gearbox generated. Quote Link to post Share on other sites
Psyche 955 Posted January 4 Share Posted January 4 Unlikely to be hydraulic lock, a clonk and stall could be gearbox related, I would separate the engine and gearbox and go from there. You are going to have to do it anyway from the sound of it. Quote Link to post Share on other sites
Frank 232 Posted January 4 Author Share Posted January 4 9 minutes ago, Psyche said: Unlikely to be hydraulic lock, a clonk and stall could be gearbox related, I would separate the engine and gearbox and go from there. You are going to have to do it anyway from the sound of it. Yes that's where my thinking is headed even if it was the engine I would expect at least some limited movement of the crank even if difficult but this thing is utterly immovable in either direction. The exhaust hose /water lock muffler configuration etc has given 20 years of trouble free service and the engine was running at the time so I cant see how it can be a water lock. Quote Link to post Share on other sites
khayyam 114 Posted January 5 Share Posted January 5 I'd guess timing failure but let's hope for something else? Separating gearbox and engine seems reasonable to me but others will know much more. Quote Link to post Share on other sites
CarpeDiem 575 Posted January 5 Share Posted January 5 Have you checked the gear lever mechanism on the Saildrive? The Morse controller can find some funny midpoint where they are in gear but the prop can still spin. Does the prop still spin if if you put it into gear? Then my next step would be to split the engine and saildrive. If you have full service records at 350 hours, I we would be making a claim under the CGA. There's no way Volvo would say that their engines might only last 350hours and that's a reasonable failure interval. If it was 3500 then that would be different... But 350 is substantially below what any normal person could consider to be the normal lifespan of a d1-20. Quote Link to post Share on other sites
Cameron 110 Posted January 5 Share Posted January 5 did you check the gearbox/saildrive oil level? Quote Link to post Share on other sites
Frank 232 Posted January 5 Author Share Posted January 5 9 hours ago, CarpeDiem said: Have you checked the gear lever mechanism on the Saildrive? The Morse controller can find some funny midpoint where they are in gear but the prop can still spin. Does the prop still spin if if you put it into gear? Then my next step would be to split the engine and saildrive. If you have full service records at 350 hours, I we would be making a claim under the CGA. There's no way Volvo would say that their engines might only last 350hours and that's a reasonable failure interval. If it was 3500 then that would be different... But 350 is substantially below what any normal person could consider to be the normal lifespan of a d1-20. The Propellor spins freely with the gearbox in neutral and the gearbox/saildrive oil level is normal, oil presents normal. Hauling out on the weekend and will split the box from the engine and we will know which half is the cause , I will post the results . As for CGA, the engine/saildrive was new in the crate purchased 10 years ago for a boat then being built DIY. The project was never completed and the owner started selling off the bits. We installed the engine four years ago and we had to disassemble the crate first. I checked with the Volvo techs as to what procedures to adopt and we followed those. My money is on the gearbox, we shall see. Thanks for the comments BTW ! Quote Link to post Share on other sites
Frank 232 Posted January 12 Author Share Posted January 12 UPDATE: Nothing unusual under the rocker cover, likewise starter motor pinion and ring gear look normal. Got on the phone to the tech at Volvo and he concludes that only a seized big end or Crank Bearing could cause it to lock up with zero lash ie all other possible culprits would exhibit at least 2 or 3mm of rotation on the crank pulley. Can't see any bad reports on the interweb with Shibaura engines in fact they are considered the epitome of rugged reliability such that even Kubota use them in some products. So its into the shop it goes and we shall see, but I will update, probably in a few weeks, bummer ! 2 Quote Link to post Share on other sites
waikiore 523 Posted January 13 Share Posted January 13 I have seen similar after exhaust mixer failure caused a hydraulic -but would be most unusual in such low hours -and yes the Shibaura engines are rugged and long lasting. Quote Link to post Share on other sites
Frank 232 Posted January 13 Author Share Posted January 13 I popped the sump and no metal particles or any visual indication of damage/failure, everything looked normal. I could see the intake valves through the induction ports and there was no sign of rust or moisture ingress. . The engine was idling at the time of failure but I suppose if there is some way the exhaust mass flow could be overcome by a water column in the exhaust then that might be a cause although the current exhaust arrangement has not altered in 25 years of use and has never caused any issues. I'm assuming after a hydrolock the engine could be turned even a little with a big spanner on the crank pulley but no it's absolutely rock solid immobilised in either direction. I dropped it off at the rebuilders this morning and they said one to two weeks to tear it down and report back. I'm sure there will be an ....Oh...... Duh ! .......(sound of hand smacking forehead) moment when they report back but I will post the results. Quote Link to post Share on other sites
John B 119 Posted January 15 Share Posted January 15 I'm checking each day for updates on the great crew.org motor mystery of the year. I dunno... I would have expected some warning on a bearing issue, noise, clatter, smoke etc. Not a catastrophic stop. How about back to the front and a concertina timing chain jam up? Or that big metal impeller, bits of, doing the same.......( if that's possible) Quote Link to post Share on other sites
Frank 232 Posted January 17 Author Share Posted January 17 No updates at this time: My son was on the boat at the time but he reports there were no unusual sounds or symptoms other than the sudden clunk, yes I'm wondering about the timing gears/chain too but I'm not sure which it has, in any case I would not have thought a complete lock up would result from that ( I could be wrong) . The biggest metal impeller is the prop and its fine as with the saildrive unit. One thing I should have removed was the bell housing cover to see if the flywheel was somehow locked up. Really the only thing confirmed thus far is its the engine not the gearbox. Quote Link to post Share on other sites
LBD 227 Posted January 17 Share Posted January 17 I know you said nothing in the sump. Did the oil level increase?... if there was water in the cylinder it would drain into your sump and you would have seen it... very very unlikely that is the cause, especially if it was running.... if you want to be doubly sure, put a little of the oil on a tea spoon and hold a lighter under it.... if it really crackles and pops as it heats, then there is some water in the oil but again unlikely to be the cause. Another trick is to put some oil in a screw top plastic bottle, put a magnet on top of the lid and turn upside down for a couple of hours. Then turn back upright leaving the magnet in place on the lid... unscrew the lid with magnet in place and see what magnetic debris is held there. Next step I would do is remove the oil filter and cut it open... try not to use a hacksaw as this will contaminate the paper with iron filings. Remove a section of paper pleats, concertina up, wrap in a rag and squash the oil out by clamping in a vice or g clamp... then open out the pleats in the sun with glasses on if your eyes are like mine and what do you see? any shiny bits? As you noted earlier the engine does not turn even a fraction... this does indicate it is engine side of flywheel, there is always a little play in the drive spline and springs in the dampener plate... oh!... I do recall having seen a polymer drive plate break and jam between the flywheel and housing a lifetime ago. I am sorry I am not in your area, I would be there swinging spanners... I love a good mechanical mystery like this. Quote Link to post Share on other sites
Frank 232 Posted January 17 Author Share Posted January 17 No visual signs of water contamination in the oil, likewise no visible indications of the engine making metal but to be fair the oil hasn't been lab analysed. My son was solo on the boat at the time but as far as I can tell none of the usual signs of advanced bearing failure presented although its possible they were there but not obvious or noticed. I dropped the engine off at the rebuilders last tuesday but it will be at least another week before they tear it down, standby to standby. Quote Link to post Share on other sites
LBD 227 Posted January 18 Share Posted January 18 5 hours ago, Frank said: No visual signs of water contamination in the oil, likewise no visible indications of the engine making metal but to be fair the oil hasn't been lab analysed. My son was solo on the boat at the time but as far as I can tell none of the usual signs of advanced bearing failure presented although its possible they were there but not obvious or noticed. I dropped the engine off at the rebuilders last tuesday but it will be at least another week before they tear it down, standby to standby. Good luck, I hope it is not terminal. 1 Quote Link to post Share on other sites
Frank 232 Posted January 21 Author Share Posted January 21 DRUM ROLL PLEASE ............................!!! Quote Link to post Share on other sites
K4309 460 Posted January 21 Share Posted January 21 9 minutes ago, Frank said: DRUM ROLL PLEASE ............................!!! Enough with the suspense already... We've been waiting months, if not years for the latest installment of what is wrong with your engine. PS, this is better than anything on Netflix at the moment 1 Quote Link to post Share on other sites
Frank 232 Posted January 21 Author Share Posted January 21 I wont keep you all in suspenders any further ........................it was............................!!!!!!!!!!!!! The bolts that attach the flywheel to a flange on the crankshaft had unwound themselves yes all of them! eventually they contacted the bell housing, ie clunk-stop. The rebuilders reckon they weren't properly torqued at the factory, no harm to the engine , they had taken the head off as a precaution but nothing wrong there. I just have to source a few gaskets for them and its all go , hopefully the bill won't be too steep for that, they said its a very common engine. Right I'm off for a celebratory G and T or maybe two then a call to Norwoods to see if I can get the gaskets cheaper than at Volvo. 6 Quote Link to post Share on other sites
